Old 02-05-2007, 10:11 PM   #1
fornvasn
fornvasn is on a distinguished road
Default someone help me!!
i got a 89mk3 turbo running way to rich. no codes, cant drive over 20mph and wont boost. there alot of black smoke coming out of the tail pipe. i just replace a head gasket and it not running right. i just install 1.2mm hks head gasket and arp studs. torque it down 75foot pound. i check the tps, mass air and timing, and i dont think there any vacumm leak. Everything seem to be with in spec...i dont know if the ECU is mess up. if someone can help me... please help.
fornvasn is offline   Reply With Quote
Old 02-05-2007, 11:47 PM   #2
dcrusupra
dcrusupra's Avatar
Check to see if theres a boost leak.
New Rebuild
My CarDomain
Old 02-06-2007, 04:20 AM   #3
mrnickleye
mrnickleye's Avatar
And after that, check to make sure your exhaust is not plugged.
Does it rev up to 5-6k in neutral??
Will it hold a steady 4k rpm for 10-15 sec. ???
Old 02-07-2007, 01:57 AM   #4
rnoswal
rnoswal's Avatar
If it ran fine before then it should after the repair. The only thing I can think of is that you might have the cam timing off. You can have either or both off and not have any mechanical damage, but it won't run very good. You might want to check your cold start injector switch or one of the other cold temp switches. If the car thinks it is always cold it will continue to run rich.
Let us know
Russ
Old 02-07-2007, 03:19 AM   #5
mrnickleye
mrnickleye's Avatar
Let us know
Russ
I agree about the cam timing. Dbl check that.
But the CSI only gets power during the cranking mode. It allows a good squirt of fuel during cranking if the coolant temp is below 56*.
Possibly some wire got pinched, cut, or not hooked up.
Old 02-08-2007, 03:19 AM   #6
OmeGa
OmeGa's Avatar
OmeGa is on a distinguished road
I had the same problem before. Its most likely a boost leak so check all of your intercooler hoses and see if they have any cracks in them or if they just are not hooked up at all.
OmeGa is offline   Reply With Quote
Old 02-14-2007, 01:57 AM   #7
fornvasn
thanks everyone for helping. i found the problem. some of the clamps was broken, so i replace it. And RUN GREAT. thanks
