Old 01-26-2007, 12:28 AM   #1
abhattan
abhattan's Avatar
abhattan is on a distinguished road
Default How much Boost on Stock Internals?
Hello guys, thanks for the help with the "Not Holding Boost". It turned out it was bad ignition wires. Got hot, and got bad. Anyway, I have an open air filter and a 3" exhaust from my downpipe back. I also have an NPR intercooler. I am about to put in a boost controller and was wondering what is the highest amount of boos I can push on that set up? Also, I will be installing a 2mm MHG soon after. What about then?
abhattan is offline   Reply With Quote
Old 01-26-2007, 01:32 AM   #2
Supra2NR
Supra2NR's Avatar
Probly a decent 12-14psi
But be sure the engine is running healthy
Beyond any doubt b4 boosting the car
A new fuel pump, and an afc to control it should be your next mods in the list
Old 01-26-2007, 10:02 PM   #3
abhattan
abhattan's Avatar
What's an AFC? I was thinking about putting in a VPC and GCC with a set of 580cc injectors, but not for another few months.
Old 01-26-2007, 10:37 PM   #4
kwnate
SP58GT
Have you heard of fuel cut?
Nate
Old 01-26-2007, 10:39 PM   #5
abhattan
abhattan's Avatar
Yea, I was also gioing to get a fuel cut defenser from HKS. Is that good?
Old 01-27-2007, 01:38 AM   #6
supraman121
Arrow
fuel cutoff is like 10-14 psi
http://www.suprastore.com/19turspec.html
Horsepower 230
Torque 245
Weight 3400-3500
Engine 7M-GTE 2954cc
Transmission R154
Boost 6.8psi
Turbo Toyota CT-26
Spark Plugs NGK BCPR6EP-N8
Injector Size 440cc
Compression 8.4:1
Cylinder Pressure 142
Fuel Pressure 33-40psi
Fuel Shutoff 11.4-13.7psi
Intercooler Efficiency 3psi drop@6.8psi
Wheels 16x7 / 225-50-16
Magnaflow exhaust NO KAT
K&N Air Filter
www.myspace.com/coreyjstevens
Old 01-27-2007, 02:22 AM   #7
abhattan
abhattan's Avatar
So that means that between 10-14 psi, the fuel will cut out? Why at that point? Is it some kind of protection?
Old 01-27-2007, 03:11 AM   #8
IHateHacks
IHateHacks's Avatar
Fuel cut is when the fuel pump can no longer flow enough fuel to supply what the injectors are demanding. Fuel pressure rises about 1 psi for every psi of boost. As fuel pressure rises, flow falls. Yes, I know that doesn't make sense but it is a proven fact. That 10-14psi range is just the general range that a stock fuel pumps' flow falls off. Now when that happens the air/fuel ratio becomes dangerously high and detonation is emminent. Thats when the ECU cuts the fuel entirely to prevent damage. You can raise the fuel cut boost range with mods like a walbro fuel pump, 550cc injectors and a lexus MAF but fuel cut will always be there. It's your engine's way of telling you you need more fuel.
Old 01-27-2007, 03:26 AM   #9
abhattan
abhattan's Avatar
okay..So do I have to use the Lexus AFM, or will the VPC be good enough? I will be using it in conjunction with a GCC anyway.
Old 01-27-2007, 07:02 AM   #10
Supra2NR
Supra2NR's Avatar
i was boostin a steady 12 without hitting any fuel cut
but then my bov broke, and the car was overboostin nut still
i was boostin a steady 10 until my bov got worst
never hit fuel cut
get an afc, a new pump, you can still stretch out the injectors
Boost and Stock Fuel collink MKIII Supra 5 03-26-2008 11:43 PM
How much boost could you run on stock 7mge internals? supraman121 MKIII Supra 2 02-22-2007 11:46 PM
boost on stock with ct26? carlosemagana MKIII Supra 8 12-31-2006 07:48 AM
boost on stock motor john buck MKIII Supra 12 11-12-2006 08:14 PM
stock boost drgnframe24 MKIV Supra 5 08-26-2006 04:12 PM
