Old 01-11-2007, 01:19 AM   #1
supraman121
Default boring a 7m na?
How much would it cost to bore the engine and would the engine need to be removed for this to be done?
Magnaflow exhaust NO KAT
K&N Air Filter
www.myspace.com/coreyjstevens
Old 01-11-2007, 01:31 AM   #2
mizuboi
mizuboi is on a distinguished road
yes and alot of money=]
my modifications
blitz nur spec catback exhaust, JDM 7m-gte, hks head gasket, arp bolts and studs, k&n air filter, Clutch masters FX300, hks SSQ bov, spearco intercooler, NGK iridium plugs
comming:
new fly wheeel
and not running
for sale
car parts for sale
misc. things for sale
stole it from sm
mizuboi is offline   Reply With Quote
Old 01-11-2007, 01:44 AM   #3
mrnickleye
mrnickleye's Avatar
The block must be stripped to bore the cylinders. These blocks are very tough, and usually not necessary to bore. When i did the valve job at 80k miles, there were still hone marks on the cylinder walls.
Call a local machine shop to get a price. Then you'll need new 'over-sized' pistons and rings, and wrist pins.
Old 01-12-2007, 11:56 PM   #4
Bill UK
AEM EMS
Bill UK's Avatar
There are specialised companies that offer engine re bore service with the engine in situ, normally the type of very large engines found in earth moving vehicles used in quarries. They claim to be able to rebore a block from 1-inch dia bore to 39-inch dia using laser alignment to ensure accuracy. Even if this was a practical and accurate way to rebore a Supra engine, there is still the problem of removing the sump to gain access to the crank and pistons which isn’t easy with the sub frame in the way. Then you would need to find a way to remove all the swalf and cast iron dust from the oil ways, some of which run from the front to the rear of the bock and are capped of with large hexagon headed grub screws concealed by the bell housing and front timing case back plate. The only way to do a re bore is as mrnickleye said remove every thing, this is my block ready for re bore I left some studs in simply because I had so many bits of engine parts lying around the house and garage, if I removed them it would only add to the problem of remembering which holes they went in. The shop that did the + .020 thou re bore charged ?90 GBP ( $176. ) and that included honing.
Nothing interesting - just boring videos DrazAdwamoi Off Topic Forum 0 11-03-2007 11:18 PM
