Old 11-16-2006, 06:45 PM   #1
teedoff00
teedoff00's Avatar
teedoff00 is on a distinguished road
Default 7MGE to 7MGTE SWAP!
Hey guys I have a really nice 1986.5 Toyota Supra and have always wanted to turbo charge it. I recently purchased a 1987 Supra Turbo, 5sp for $800. I want to just swap the engines. I was wondering if anyone has done this? Are there any problems to watch for? Tips/tricks? I would also like to know if any preventative mantainance should be done. The 87 has about 155,000 miles, the engine runs strong, no problems, or knocks. I was going to replace the head gasket and put in a metal one. Any one know what brand is best, mm, etc? I was thinking of a 1.5 or 2.0 mm. Any help would be appriciated!!
Thanks
teedoff00 is offline   Reply With Quote
Old 11-16-2006, 08:58 PM   #2
tone loc
tone loc's Avatar
do some searching on this forum because there has been a lot of talking about engine swaps. if you want more specfics let us know.
Old 11-16-2006, 09:50 PM   #3
jfunez
jfunez's Avatar
it should be very straight forward swap...nothing different than the na, just remove and replace.
as far as preventive, i would replace all gaskets including oil pan,cam seals,turbo gaskets and head gasket. I had my head machinned I believe 20 thousands and ended up using a 1.4 mm titan motorsports metal headgasket and arp studs and so far no leaks...thanks to the supra gods..lol
Old 11-17-2006, 04:20 AM   #4
teedoff00
teedoff00's Avatar
How much boost are you running?
Old 11-17-2006, 04:53 AM   #5
j3pz
the size of the hg depends on how much the head/block are machined
Old 11-18-2006, 12:11 AM   #6
supraman121
i asked the same thing like two days ago same year car just mine looks worse lol i was told if manual i was probly going to need a clutch upgrade and they said the computer was compatable but it's an na computer so i think you or i would probly have to get the computer erased and redone at a dyno shop but other then that everything i was told will bullet up engine trains
Magnaflow exhaust NO KAT
K&N Air Filter
www.myspace.com/coreyjstevens
Old 11-18-2006, 07:58 AM   #7
j3pz
i believe there is a thread in the faq section...
ah haha i was right
http://www.toyota-supra.info/forums/...ead.php?t=1212
use the second link
7mge to 7mgte swap doodah Non-Generation Specific Questions 1 01-28-2007 06:50 AM
7mge motor to 7mgte; no motor swap boogum7 MKIII Supra 9 12-10-2005 04:19 PM
7mge to 7mgte without swap? Stuba MKIII Supra 1 10-18-2005 03:37 AM
