Old 11-15-2006, 08:38 PM   #1
motosparky
motosparky is on a distinguished road
Default Shift lock on automatics
I changed the brake master cylinder on my 89 NA Supra, put everything back in place but since then I have to use the shift lock over ride to get the car out of park.
I have scoured the manual and this site and have no idea how to either adjust it or repair it !
My throttle position sensor code is on, but I do not know if that has any effect on this !
Any help would be appreciated.
Thanks !
motosparky is offline   Reply With Quote
Old 11-15-2006, 08:51 PM   #2
ravenmaster
ravenmaster's Avatar
Hmm the 87 N/A auto didn't have the shift lock mechanism so I am not sure. And you checked the linkage?
1988 Toyota Supra Turbo Targa
Old 11-15-2006, 08:58 PM   #3
motosparky
All I changed was the brake master cylinder.
Other than not going all the way to the floor, I had to change nothing ..
http://www.cygnusx1.net/Supra/Librar...on=AT&Page=142
Old 11-16-2006, 03:50 AM   #4
jfunez
jfunez's Avatar
make sure the brake light switch is working properly and is hooked up, many cars have two switches on the brake pedal, Im not sure how many our supras have but there should be one under the steering wheel attached to the brake pedal....look for it and make sure they are hooked up.....
one thing to look for is...ARE YOUR BRAKE LIGHTS WORKING?
Name:	greatest supra.jpg
Old 11-16-2006, 04:59 AM   #5
http://www.cygnusx1.net/Supra/Librar...tion=D&Page=10
brake light switch is first thought. Fuse is another.
Old 11-16-2006, 08:34 PM   #6
motosparky
That was the ticket !
Fuse was not visably blown but I replaced it and it works ...
Thanks...
Happy Holidays Nick : )
Old 11-17-2006, 12:03 AM   #7
Thanks...
Thanks. I hope so. I just today had a root canal on an upper molar. Kinda dopey now. More work to come after T-day.
Don't ya just love those quick and simply car fixes ??
What RPM do you shift at? ogkush Road Racing & Autocross 5 11-04-2010 07:58 AM
Passenger Door Wont Properly Lock SideWinderGX Car Audio and Alarms 2 03-03-2009 09:08 PM
1985 supra doors won't lock mowvideo MKII Supra 0 11-18-2007 09:57 AM
Question for someone who has actually seen the outside rear lock mechanism finaltable MKIII Supra 0 10-22-2007 02:44 PM
shift lock overide supra_91 Non-Generation Specific Questions 2 09-29-2005 01:34 PM
