Old 11-15-2006, 08:51 AM   #1
west_side_supra
west_side_supra's Avatar
Default No release
ok i have the HKS SSQV ebay clone BOV, and the damn thing will not release pressure, ive played with the little screw on the back of it and it still will not open, i dont know whats going on. any ideas? besides that its a ripoff model
7MGTE - 500hp never dyno'd
fidenza cam gears
Old 11-16-2006, 02:49 AM   #2
west_side_supra
anyone? please help?
fidenza cam gears
Old 11-16-2006, 03:39 AM   #3
jfunez
jfunez's Avatar
do you have your small vacuum\presure hose conected to it?
Old 11-16-2006, 05:35 AM   #4
west_side_supra
ok im useing the stock bypass valve vacume line, i have the BOV on the IC pipe. and it is all sealed there are no leaks what so ever. heres my pretty little drawing of how it is installed
I know im a pro hehe
fidenza cam gears
Old 11-16-2006, 08:53 PM   #5
Isphius
Isphius's Avatar
Make sure the spring is adjusted all the way out, and then turn it back in till it sounds like it works right. It should only open when you let off the gas. Did you actually try driving the car or just revving it in the driveway?
Old 11-16-2006, 09:52 PM   #6
west_side_supra
i have tryed it all the way out and all the way in, i have gotten nothing. i can hear the turbo wind down, kind of a fluttering noise. like chi chi chi, and i have tryed doing it while driving and while in my driveway, nothing at all. now if i rev the engine and push the gasket open with something then it blows off. so the valve is working, is the spring to tight in there? cause its really a hard push
fidenza cam gears
Old 11-17-2006, 12:06 AM   #7
dcrusupra
dcrusupra's Avatar
Oooo, I've heard about the eBay HKS knockoffs. I also heard that you're supposed to lube it also.....
New Rebuild
My CarDomain
Old 11-17-2006, 12:17 AM   #8
jfunez
jfunez's Avatar
Originally Posted by dcrusupra
Oooo, I've heard about the eBay HKS knockoffs..
so what youve heard...is it good or bad....? give an Idea of what kind of quality you are getting...
Old 11-17-2006, 04:40 AM   #9
Isphius
Isphius's Avatar
Yeah put some oil on it. I know my stock BOV made that cahahahah noise, And i know it was working cause my friend reved it up and i could feel the air come out when i pulled it out of the accordian and plugged the hole. But yeah, Put some grease or something on it, And try it on a different vaccum hose. Make sure its one behind the TB though lol. I might get that ebay ssqv clone if you can ever get it to work.
Old 11-17-2006, 06:52 PM   #10
west_side_supra
ok so what i have done is cut the spring inside of it. thinking that maby there may have been to much tension on it, and not enough pressure. well its on that track the spring now has about 2 coils cut off of it, and its still not opening. so now what i wonder is where can i buy a spring for the inside of this bov, maby a less tense one. i know hks has one for the racing pop off BOV but not the ssqv. is the spring for the pop off one the same?
oh i also lubed it up and it still would not open up.
fidenza cam gears
Take out Release Fork? FunWheelDrive MKIII Supra 2 03-24-2008 05:33 AM
87 supra hood release problem EvilDragun Non-Generation Specific Questions 6 01-11-2008 01:38 AM
Hood release cable catawalks Non-Generation Specific Questions 11 04-24-2007 03:04 AM
Quick release hub adapter!? 88Supraboy MKIII Supra 4 03-04-2006 04:10 PM
Quick release hub adapter 88Supraboy Non-Generation Specific Questions 0 03-02-2006 01:55 PM
