Old 11-12-2006, 02:37 PM   #11
Supra2NR
Supra2NR's Avatar
Becuase of a few things:
1. If you have a stock headgasket say goodbye to that. You want more boost than 9_PSI? Buy a BHG.
2. You will hit fuel cut past this. (9 _PSI is a rough number)
thank you very much
what about if u already got a MHG ( i think thats what u meant too)
and i know weathere is a factor too
what about if its about 30' outside?
Old 11-12-2006, 03:26 PM   #12
j3pz
no you wont hit fuel cut after 9 psi. ppl boost up to 15psi on the ct26 before fc, however the ct-26 is said to lose effeciency after 13psi. also if you've already retorqued the head turnin up the boost a lil will be fine. and ive heard the stock internals are good up to i think its 500hp but im sure if you get up that high you may have already changed them
Old 11-12-2006, 08:14 PM   #13
Supra2NR
Supra2NR's Avatar
alright thanx a lot for the info
probl raise it up around 9-10 psi depending on the temp
Boost and Stock Fuel collink MKIII Supra 5 03-26-2008 11:43 PM
How much boost could you run on stock 7mge internals? supraman121 MKIII Supra 2 02-22-2007 11:46 PM
How much Boost on Stock Internals? abhattan MKIII Supra 26 02-20-2007 06:30 PM
boost on stock with ct26? carlosemagana MKIII Supra 8 12-31-2006 07:48 AM
stock boost drgnframe24 MKIV Supra 5 08-26-2006 04:12 PM
