Old 11-08-2006, 10:16 AM   #1
mizuboi
mizuboi is on a distinguished road
Default hks TT install
hey guys i need a quick diagram of how to install my turbo timer fdrom hks umm a picture of the connections would be nice just frum under the dash you know the three wires plus grounding the harness is already hooked up just need to know where the other three plus grounding wires should go
my modifications
blitz nur spec catback exhaust, JDM 7m-gte, hks head gasket, arp bolts and studs, k&n air filter, Clutch masters FX300, hks SSQ bov, spearco intercooler, NGK iridium plugs
comming:
new fly wheeel
and not running
for sale
car parts for sale
misc. things for sale
stole it from sm
mizuboi is offline   Reply With Quote
Old 11-09-2006, 09:16 AM   #2
mizuboi
anyone? please? help me yah?
my modifications
comming:
new fly wheeel
and not running
for sale
car parts for sale
stole it from sm
Old 11-13-2006, 11:23 PM   #3
mizuboi
bump...,,,
my modifications
comming:
new fly wheeel
and not running
for sale
car parts for sale
stole it from sm
Old 11-13-2006, 11:30 PM   #4
Bill UK
AEM EMS
Bill UK's Avatar
You may find it here. http://www.hksusa.com/faq/?ID=1647
Old 11-14-2006, 10:16 AM   #5
mizuboi
that did not help much because i want to know where the wires go like pictures or descriptions of where they are on the supra i already have this paper with my turbotimer
my modifications
comming:
new fly wheeel
and not running
for sale
car parts for sale
stole it from sm
Old 11-15-2006, 05:24 PM   #6
mizuboi
please anyone?
my modifications
comming:
new fly wheeel
and not running
for sale
car parts for sale
stole it from sm
Old 11-15-2006, 05:50 PM   #7
tellfromchico,ca
tellfromchico,ca's Avatar
tellfromchico,ca is on a distinguished road
Talking
thanks! ive had a hard time trying to find that again on the hks site.
tellfromchico,ca is offline   Reply With Quote
Old 11-16-2006, 06:34 AM   #8
west_side_supra
west_side_supra's Avatar
ok i can help you with the main turbo timer part, i know what you are going through, i had the same issues.
1.you will have to start by taking the plastic cover off that has the hood release on it.
:ATTACHING THE IGNITION WIRE:
once you have removed that you should be able to see your steering colum and all that, on the steering colum or near it there should be a big black connector that has alot of wires comeing out of it, probably 12-18 wires. disconnect that and look for a black with orange stripe wire on the connector closest to the steering wheel. "i recommend useing a vampire splicer for this.
:ATTACHING THE E-BRAKE SENSOR CABLE:
take your dash apart by unscrewing all of the screws and then pop that baby off. By your shifter there will be 2 screws, take those off. next inside the mini compartment by your tems unit switch there will be 1 more screw that you need to unscrew. pop off your shifter console. Now if you havnt already done so take off the e-brake cover, now down by the e-brake you will see a little sensor that kinda looks like this
______
|=|______|------
its small and black, looks like a push button, and its near the bottom of the ebrake
you will need to use another vampire splice connector for the wire comming off of it.
:POWER AND GROUND WIRE:
find yourself a ground and a possitive and hook it up.
before you start to put everything back together put your key in the igniton and turn it to the ON possition, the turbo timer should turn on. then take the key out and it should start to do a count down.
if the turbo timer didnt turn on, make shur to check your possitive/ground/e-brake sensor
if all else fails i forgot to add a step. hope this helps your, ill add more to it when i figure out how to hook up the speed and RPM signal wires up. Good luck
7MGTE - 500hp never dyno'd
fidenza cam gears
Old 11-16-2006, 06:44 AM   #9
mizuboi
thanks! but what i really needed was the rpm and speed cables that thingy i need to splice those but i don't know which ones they are
my modifications
comming:
new fly wheeel
and not running
for sale
car parts for sale
stole it from sm
Old 11-16-2006, 06:48 AM   #10
west_side_supra
well im still waiting on my toyota shop manual for the supra, when i recive it i will tell you what the wires are. ill take a quick look around, you know anything on BOV's?
fidenza cam gears
anyone install aftermarket stereo? dannydavi Car Audio and Alarms 10 03-17-2012 10:41 PM
water temp gauge install sundevil1 MKIII Supra 3 12-09-2008 04:38 PM
how much wat it cost to buy and install a 1jz? 5upra lov3r MKIII Supra 2 09-08-2008 11:33 PM
7mgte install in na 86.5 supraman121 MKIII Supra 1 01-13-2007 03:04 AM
how do I install hks ssqv? akinaperformance MKIII Supra 0 06-05-2006 06:33 PM
