Old 01-18-2008, 08:13 PM   #11
carfanatic89
carfanatic89's Avatar
What about your guages how would you make the guages display what the new 350 and trany are doing, the guages run off the ECU dont they.
Supra Engine Powered Dragster
Old 01-18-2008, 10:44 PM   #12
Using stock gauges probably won't work, due to differences in resistance values/wiring between gauges and sensors on the new motor. Would probably have to go with after market gauges that are wired independently. The ECU is only really needed with fuel injection/emissions controls, so if you're swapping in a carburetted 350, you're not gonna be able to pass emissions, and therefore don't need to worry about controlling them.
Unless you want to do your part in protecting the planet.
Then you should get a POS Prius.
Old 01-20-2008, 06:55 AM   #13
oowee623
oowee623's Avatar
Originally Posted by das_reich1984 View Post
allso any recommendations. on Trany, rearend combo.
i'd recommend a 1jzgte with r154 transmission and either a 3.73 lsd, 3.91 lsd, or 4.10 torsen. it will cost you no more than 6 grand
89 white package twin turbo
Originally Posted by supradaddy0803
the results of your work will be very nice when you push the gas and hold on for dear life.
Old 01-20-2008, 09:03 AM   #14
indytrucks
indytrucks is on a distinguished road
Originally Posted by Isphius View Post
You will never be able to get an ls1 car that cheap. lol. At least not around here. Even a crashed trans am or camaro around here is 7 or 8k with all its drivetrain intact. Plus, LS1s are very expensive and hard to get parts for. Go with a straight up small block, the 55-86 kind. That is the most comon motor in the world. More than 55 million produced. And I would suggest going auto. No clutch to mate up, the shifter wont end up in the wrong place, etc. Then all you have to do, is measure your driveshaft and take it to a good shop to get it chopped down and get a chevy U joint put on the end. And then with a carb you dont have to worry about computers, wires, fuel return lines, sensors, etc. Just a fuel line, a few vaccum hoses, and a battery wire. lol. I would love to put some sidedraft carbs on a 7mge. Yay for power.
Dude have you cracked open a Jegs or Summit catalog lately? There are tons of LS1 parts. Including a cab mani out there. Check out some of thr RX7 websites. Those guys do LS1 swaps all the time. Might help. Good luck.
indytrucks is offline   Reply With Quote
Old 01-24-2008, 12:09 AM   #15
Isphius
Isphius's Avatar
nice 1+ year revival
Old 01-24-2008, 12:10 AM   #16
Isphius
Isphius's Avatar
yes but there expensive and i was talking like the coil packs, factory intake manifolds, sensors, wiring, etc unless you have a donor car
Old 04-14-2008, 03:16 AM   #17
regosasupra
regosasupra is on a distinguished road
Exclamation
i really need help..
engine
Im lookin to do an engine swap for my 89' supra from the stock 7mge to the 7mgte but im looking for something more than a 30hp raise from the turbocharger.. it would really help me if you guys knew of any other engine swaps i could do..
regosasupra is offline   Reply With Quote
Old 04-14-2008, 05:25 AM   #18
oowee623
oowee623's Avatar
engine
1jzgte/2jzgte
Old 04-20-2009, 12:42 AM   #19
Vacationtime247
Default 1987 Toyota Supra MKIII 350 Chevy V8 Vortec 700R4 Project Car
Here are a few videos of my 1987 Toyota Supra MKIII 350 Chevy V8 700R4 Swap. It's easy to do and probably cheaper than a rebuild or modified Toy motor.
http://www.youtube.com/watch?v=jalkpCrrD2I
http://www.youtube.com/watch?v=IsRxh7A3JT8
http://www.youtube.com/watch?v=MVoVNRaJmQI
http://www.youtube.com/watch?v=k2QtXIKyXH8
http://www.youtube.com/watch?v=hacynXk4T8g
http://www.youtube.com/watch?v=VbDVRxTUJZk
VT247
1988 supra engine rebuild 1988Suprakid MKIII Supra 5 06-07-2006 09:07 PM
