Old 10-27-2006, 02:02 PM   #1
das_reich1984
das_reich1984 is on a distinguished road
Default 1988 supra. 350 v-8 engine swap?
any good links you guys know of where they did this swap. any info anyone can give me would be nice. i tried searching the site couldnt find anything. i bought the car about a year ago with dreams of building a bad ass turbo car. now i just want a fast as car without all the trouble of turbo's and electronics dont get me wrong turbos own. i just dont have alot of time to dump into the build. i train atleast 3 hours a day plus i have a job. thinks for reading.
das_reich1984 is offline   Reply With Quote
Old 10-27-2006, 02:04 PM   #2
das_reich1984
allso any recommendations. on Trany, rearend combo.
Old 10-27-2006, 05:33 PM   #3
ravenmaster
ravenmaster's Avatar
Location: Being not duly informed, I refuse to answer with any degree of accuracy for fear of prevaricating
ravenmaster is on a distinguished road
Das....just swap in the 2JZ...its cheaper and its easier. The V-8 swap is a p-ain in the arse. The wiring is diffrent and if you dont have alot of time than the V8 is not something you want to do.
1988 Toyota Supra Turbo Targa
Originally Posted by supramacist View Post
Ya I'm the a$$hole. I think you're still mad raven cause I thought from your handle that you were a chick. I said I was sorry for that.
ravenmaster is offline   Reply With Quote
Old 10-28-2006, 09:57 AM   #4
das_reich1984
how much for everything i need to put in a 2jzgte. i broke the tranny when i took it out so i'm gona need one of them. computer and wiring harness.i dont see how this will be cheaper since i was going to put in a carburated v-8. the rubuild on the things are as cheap as a crankshaft for a 7mgte.
Old 10-28-2006, 04:32 PM   #5
Isphius
Isphius's Avatar
It would def not be cheaper to put a 2jz in. lol. Whats good about a 350, You can get a stock HO with 330 hp and 380 ft lbs of torque. And it will last forever as long as you keep the temps down and the oil changed.
Old 10-29-2006, 02:52 PM   #6
das_reich1984
i have found a 6sp transmission i'm thinking about using. my goal for the car is a faux ferrari. by that i mean high reving v-8,nice sound. the bank is gona kill me though.
Old 10-29-2006, 07:22 PM   #7
WiseAssJester
WiseAssJester is on a distinguished road
Good luck with the swap.
Let me know how it goes, I'm interested. Particularly in the tranmission selection and work.
Gonna go with any kind of forced induction(Super, turbo, nitrous)?
WiseAssJester is offline   Reply With Quote
Old 10-30-2006, 08:14 PM   #8
89soup
89soup's Avatar
89soup is on a distinguished road
Why not do an LS1 with a T56?
You can pick up a wrecked LS1 Camaro or TA for $3,500 and under.
89soup is offline   Reply With Quote
Old 10-31-2006, 02:08 AM   #9
Isphius
Isphius's Avatar
You will never be able to get an ls1 car that cheap. lol. At least not around here. Even a crashed trans am or camaro around here is 7 or 8k with all its drivetrain intact. Plus, LS1s are very expensive and hard to get parts for. Go with a straight up small block, the 55-86 kind. That is the most comon motor in the world. More than 55 million produced. And I would suggest going auto. No clutch to mate up, the shifter wont end up in the wrong place, etc. Then all you have to do, is measure your driveshaft and take it to a good shop to get it chopped down and get a chevy U joint put on the end. And then with a carb you dont have to worry about computers, wires, fuel return lines, sensors, etc. Just a fuel line, a few vaccum hoses, and a battery wire. lol. I would love to put some sidedraft carbs on a 7mge. Yay for power.
Old 11-24-2006, 11:42 PM   #10
lightwolf87
lightwolf87's Avatar
lightwolf87 is on a distinguished road
Default 389 ci. chevy in 1986.5 supra
I started building a fast, reliable, cheap, sleeper. Out of a 1986.5 supra, of course the cheap didnt last too long with the 2-stage nitrous, forged pistons, forged crank, pink rod and 10.5 compression. backed with a 700-4r tanny. the einge only costed me 3, maybe 3500$. Any tips on enigne mounts was gonna go with front mounts but need to hook up a/c comp and P/S Too.
lightwolf87 is offline   Reply With Quote
1988 supra engine rebuild 1988Suprakid MKIII Supra 5 06-07-2006 09:07 PM
