Old 10-26-2006, 07:43 PM   #1
glanzbo
glanzbo is on a distinguished road
Default Car won't start!
Hi guys I'm posting a question for a friend to be answered by you(hopefully). My friend has a mark 3 supra turbo im unsure of the year as everytime I've seen it he hasn't had plates on it. I was hoping anyone had idea's on why it wouldn't start. This is what happened:
  • He recently replaced the headgasket.
  • The petrol is getting a spark.
  • The timing is lined up.
  • The car won't start!
Hopefully you can help thanks in advance Rob.
glanzbo is offline   Reply With Quote
Old 10-26-2006, 09:12 PM   #2
ravenmaster
ravenmaster's Avatar
Man more info needed! btw you can narrow down the MKIII su-pra to within two years by body diffrences (lights mirrors,etc) not huge diffrences but enough.
Anyway there are a great deal many things that could be wrong. have you checked the Cold Starter? ANswer these questions -please;
1. Is it N/a (Naturally Aspirated) or turbo?
2. Did it start before the head gasket change?
3. Any mods?
4. manual or auto?
1988 Toyota Supra Turbo Targa
Old 10-26-2006, 10:12 PM   #3
Bill UK
AEM EMS
Bill UK's Avatar
Check anything to do with the timing, No1 piston is at top of stroke, crank pulley timing markings read zero, cam pulleys markings are at the top, cam sensor installed correctly.You can download the complete service manual from this link. 1990 MK3 Supra TSRM Text Edition(51.4MB)
Old 10-26-2006, 11:03 PM   #4
dcrusupra
dcrusupra's Avatar
Is there any fuel getting into the engine?
New Rebuild
My CarDomain
Old 10-27-2006, 05:47 PM   #5
glanzbo
3. Any mods?
4. manual or auto?
Sorry buddy, it is turbo, it did start before the head was done, no modifications, and it's manual thanks a million for any advice.
Old 10-27-2006, 05:49 PM   #6
glanzbo
Yes there is.
Old 10-28-2006, 02:57 AM   #7
rnoswal
rnoswal's Avatar
Well you need fuel, spark and air. Sometimes the connector from the distributor doesn't make a good connection and won't fire. Make sure the ground wires are back on under the intake. There may be two sets of wires with eyes on them that aren't bolted on and it won't start without the ground. The airflow meter has to have a good plug on it too.
Start at the beginning and make sure the front cylinder is at tdc on its compression stroke and then put the timing mark about ten degrees after tdc. Put the plugs in, make sure they are in the correct firing order, 153624. Check to see that the plug to the coil pack is plugged in. As the wiring gets older and mor brittle, some of the plastic locks break and don't keep a good connection so you may have to wiggle connectors while turning the engine over.
The timing has to be close though or it won't start. If it is 180 degrees out it will back fire so you know at least you are getting fuel and spark, but the timing is off. The cams have to be set too. Again #1 piston tdc, align the notches with the dots on the cam gears and get the timing belt on without moving the cams. There are ways to make sure the cams are timed just right by moving the gears and the dowel pins, but you have to know what you are looking for as far as timing belt tightness and correct cam gear timing. So just do the basic cam timing and even though the cams may be off just a bit they shouldn't be off by even one tooth.
The engine is a non interference head so you won't bend a valve by having the timing off, but it won't run either if they are off. By this time the distributor is going to be off so you should have marked it first, but if you didn't then you should leave the bolt a little loose and when you think everything else is right, have someone turn the engine over and move the distributor slowly one way or the other and see if you get anything.
Let us know how it goes.
Russ
Old 10-28-2006, 03:30 PM   #8
glanzbo
Russ
He was told that it was an interference head so he's guessing it could be the timing also he was confused about the bit where you talked about the distributor as he found three coils but no distributor i think. Thanks again for all the help guys any more input would be great.
Old 10-28-2006, 06:09 PM   #9
h8z2luze
h8z2luze's Avatar
Supras are non interferance engines.... Unless he messed with the cam settings or something I dont see how that would have an effect. Maybe he forgot to plug in a connector. I did that when I replaced my HG It ended up being the MAF connetor lol. It has a coil pack cause its a turbo n/a have distributors.
Old 10-28-2006, 11:37 PM   #10
twurbo.oggy
twurbo.oggy's Avatar
twurbo.oggy is on a distinguished road
he said it was turbo. so he's got coil packs bro
only thing i can think would me MAF. or some stupid wire/hose. make sure everything is connected
twurbo.oggy is offline   Reply With Quote
Car Died...where to start? Jrew MKIII Supra 4 10-26-2007 02:19 PM
