Old 10-25-2006, 05:02 PM   #1
palmerawesome
palmerawesome is on a distinguished road
Default mk3 potential
i love the supra, i have since i first became a motor head. i am looking to buy a mkiv but know i can get a mkiii for much cheaper. what kind of speed could i get out of an mkiii if i put 1500 into the engine. anybody got any ideas
palmerawesome is offline   Reply With Quote
Old 10-25-2006, 05:09 PM   #2
rnoswal
rnoswal's Avatar
Most of the good horsepower gains are in the heads, so work on that. Little bigger valve, play with the cam timing some and make sure the porting job is down right. Header, pipe and muffler should be low restrictive and a good air filter. Advance the timing as far as you can with the fuel you use and it will be better........enough........well who knows untill you find a challenge.
Russ
Old 10-25-2006, 06:43 PM   #3
palmerawesome
thank you, russ. but surely not a all that can be done for $1500
Old 10-25-2006, 08:04 PM   #4
smoo215
smoo215 is on a distinguished road
1500 is just scratching the surface. get the car you desire most
smoo215 is offline   Reply With Quote
Old 10-25-2006, 08:29 PM   #5
tone loc
tone loc's Avatar
mkiii is a cheaper to mod by the way
Old 10-26-2006, 09:18 PM   #6
ravenmaster
ravenmaster's Avatar
Location: Being not duly informed, I refuse to answer with any degree of accuracy for fear of prevaricating
ravenmaster is on a distinguished road
Two major diffrences in the two cars ( iwill be going with the turbo here):
1.The Engine:
MKIII: 7MGTE 230HP stock
MKIV: 2JZTE 340?HP stock
2. The body weight:
MKIII Is a little to alot heavier...all metal body fenders etc...come to think of it the only parts that isn't metal is the bum-pers. LOL the MKIV had a mix between metal and fiberglass so it weighs lesss. I -prefer the MKIII's myself but its a mater of what you most like
1988 Toyota Supra Turbo Targa
Originally Posted by supramacist View Post
Ya I'm the a$$hole. I think you're still mad raven cause I thought from your handle that you were a chick. I said I was sorry for that.
ravenmaster is offline   Reply With Quote
Old 10-27-2006, 01:45 PM   #7
palmerawesome
Default well thanks!
thanks every body you helped me alot! i've decided to go with the mkIII. i was readin my local auto trader....(they should make a subscription service. i mean i buy it every week ) anywho alot of the cars have blown head gaskets. i am under the impression this is caused by running the engine too hard. i am also under the impression that before i start upgrading my mkIII i should make a few mods to insure the cars well-being, such as aftermarket clutch, aftermarket head gasket, etc.
would anybody be so kind as to tell me what would be some good parts like ^above to buy before i increase horse power?
thanks, NewB
Old 10-27-2006, 05:21 PM   #8
ravenmaster
thanks, NewB
Definitly get an aftermarket head gasket, even if you don't intend on upgrading the horse-power. MKIII's are rather notorious for blowing these. (We drive our cars hard) and the Aftermarket gasket is fairly cheap and works really well. Plus its peace of mind.
1JZGTE Horsepower potential? Ungoliant MKIII Supra 18 08-06-2014 09:28 AM
Advice on Potential Buy RyDeFly MKIII Supra 7 12-07-2005 05:06 AM
86 Supra Turbo Potential? AJM187 MKIII Supra 4 10-04-2005 03:30 PM
