I have a 88 supra turbo. When i boost i can hear the turbo and feel it a little but it dies out after like 1 second of boosting. It doesnt hold a boost.what could this be?wastegate?thanks
how high does it boost to? have you checked all of your hoses and clamps?
i am going to check my clamps and hoses.my meter says im boosting to 6 or 7.
is it auto or standard??
its 5 sp.
my car used to do that when my clutch was slipping. i put in a new clutch and she boosts really hard, esspecially on uphills. does it go to 7, drop to 3(roughly) then 0?
YEA IT BOOST UP FINE.I WAS TOLD IT WAS MY WASTEGATE. DO OYU KNO HOW I CAN CHECK MY WASTEGATE?IF IT IS THAT?THANKS
wastegate or the wastegate solenoid? my friend told me that its more likely to be the solenoid that controls the boost. it should be by the driver side strut under the hood.
OK THANKS IM GUNNA CHECK.
no no no no no LOL
the solonoid by the strut tower is the turbo pressure sensor which just tells the cluster what boost to display ;) if you are losing boost or idling rough or puffing out alot of black smoke... "alot"... then check your intercooler pipes as you most likely have a leak usually the pipe coming of the turbo to the intercooler is a culprit... also check the hose between the 3000 pipe and throttle body... or if you intake is cracked got a hole etc basically you are looking for a leak between the air flow meter & the throttle body... if a leak is your problem please describe in more detail "without caps lock on" what your supra is doing Thanks |
hey i replaced the wastegate but the turbo still isnt holding a boost.But when i was replacing the wastegate. i took off the accordian pipe.(the intake pipe that goes to the turbo) and it was ripped.And it is obviously leaking air.could that be my problem?my friend said that wouldnt make my turbo weak like that but you never know.thank you
the hole in the accordian/intake pipe will cause you to hit fuel cut and there will be lost of power as you will be running rich.... get a new intake pipe and check all of your intercooler pipes for the same thing, cracks, or slipped off etc
| All times are GMT. The time now is 06:34 AM. |
