G'day guys
I am a new member here and i have recently bought a 1991 supra with a 1JZ-GTE. Performance wise its stock with 105K on it. I was just wondering if anyone knew What sort of turbos came stock on them? How much PSI can they run? Also if anyone knows how would my car go againest a basically stock R33? if ya have a good website for some research just let us know Thanks |
they are CT12a's two of them infact. Would not run over 14psi with them. Ceramic wheels dont hang on to well. If both you and the R33 are stock...then you should win:)
yup what ma70-1jz said hehe
good ol ct12a's we have run 18psi on the twins and didn't kill them... but do bear in mind we had all the fuel mods to match the factory 1jz map sensor only reads to 14.7 which is where fuel cut is as well... so 14 should be sweet till you need to start ticklin her ;) |
oh yeah...forgot to mention that the stock ct12a have enough flow to ecplise 240rwkw :D which is a LOT more than old mate in his R33 GTS-T
oh LOL
ma70-1jz... you're damned right hehe the back one was steel but front wasn't hehe my bad ;) |
why did you only have one done???? |
how much was it to have done:huh: |
well i supposed it worked like turbos normally do lol
the back one is the main one that fails terribly on the 1j from what i know so we only got that one done and never had another problem :D actually not sure how much it was to do will find out tomorra ;) |
cheers!!!!
well i found out he spend $1400 on doing the steel conversion... diff wheel diff shaft and a hellava lot of machining ;)
| All times are GMT. The time now is 12:39 PM. |
