Old 10-14-2006, 10:54 AM   #11
Targaturbo
Targaturbo is on a distinguished road
What are you trying to do?
Originally Posted by ravenmaster
When drainind tranny fluid from the plug on the bottom of the tranny, does that drain it all or just from the pan? If it is just from the pan how can i get it all out?
Targaturbo is offline   Reply With Quote
Old 10-14-2006, 03:24 PM   #12
Bill UK
AEM EMS
Bill UK's Avatar
Totally drain the auto transmission box! there’s about 7 litres in there undoing the drain plug will only drain 2 to 3 litres. How do you totally drain the remaining litres ?
Old 10-14-2006, 05:15 PM   #13
nelly26
nelly26 is on a distinguished road
hi ravenmaster i have sent you page sorry i have been out all day
nelly26 is offline   Reply With Quote
Old 10-14-2006, 06:06 PM   #14
Bill UK
AEM EMS
Bill UK's Avatar
Try this link the second and last files work as a PDF download, which you can then save on your computer. http://filecab.supra-tsrm.com
Old 10-14-2006, 08:07 PM   #15
ZauggIt1
ZauggIt1's Avatar
ZauggIt1 is on a distinguished road
THe only way possible to get all the tranny fluid out is to co to a shop that flushes them. You can not get all the fluid out by just pulling the plug. THe torque converter is full of fluid. that is were most of it goes. You have to get something done called a T-Tech Trans flush.
Drive it like you stole it!!!
ZauggIt1 is offline   Reply With Quote
Old 10-14-2006, 08:18 PM   #16
mad_dicer
mad_dicer is on a distinguished road
yes a t-tech is one of the only ways to get all the fluid out.but first ya gotta look at how many miles are on the tranny.and when it was last serviced.i have the t-tech machine at my shop but i will NEVER flush one out over 150k.
when it gets to that point if its not regulary maintained its wise to just drop the pan and change the filter and clean all the junk out of the bottom and magnet. if ya got more miles then that i would just suggest draining and refilling only whats in the pan. believe it or not but ya can kind of send the tranny in shock and it will fail.
mad_dicer is offline   Reply With Quote
Old 10-15-2006, 01:12 AM   #17
ravenmaster
ravenmaster's Avatar
Hmm after hearing the thing about the Dexron I am kinda wondering if putting Trick Shift in my car id a good idea...
1988 Toyota Supra Turbo Targa
Old 10-15-2006, 04:47 AM   #18
Isphius
Isphius's Avatar
With the drain plug out, Start your car up and let it idle a little. Dont change the gear. That will pump any remaining fluid out. And when you fill it up there is a specific way you have to do it, I am not sure. You have to let it idle for a long time though.
Old 10-15-2006, 07:25 AM   #19
ravenmaster
Is it safe to put trick shift in my car?
Old 10-15-2006, 02:51 PM   #20
tone loc
tone loc's Avatar
whats trick shift??
Amt. of tranny fluid from "cool" to "hot". go.stfu MKIII Supra 2 08-13-2007 07:05 PM
Draining Transmission Fluid? RNEMESiS42 MKIII Supra 20 05-17-2007 10:17 AM
Fluid Reccomendations. Such an improvement! ravenmaster MKIII Supra 9 10-23-2006 05:15 PM
tranny fluid tone loc MKIII Supra 9 10-23-2006 04:06 AM
W58 tranny fluid dcrusupra MKIII Supra 0 01-19-2006 03:26 AM
