Old 10-13-2006, 04:27 AM   #1
ravenmaster
ravenmaster's Avatar
Default Rear shock question
My buddi and I are puttinh on the KYB GR-2's but it does not say anywhere I have found to put the stock spring back on. Are you supposed to or not? Thanks guys,
Chris
1988 Toyota Supra Turbo Targa
Old 10-13-2006, 03:46 PM   #2
ravenmaster
Chris
nobody? please?
Old 10-13-2006, 04:28 PM   #3
nelly26
nelly26 is on a distinguished road
does the new shocks come with springs
nelly26 is offline   Reply With Quote
Old 10-13-2006, 05:09 PM   #4
ravenmaster
no they are KYB GR-2's
Old 10-13-2006, 05:14 PM   #5
ravenmaster
and also I meant COIL not spring but I think you knew that
Old 10-13-2006, 05:23 PM   #6
nelly26
to tell you the truth with part nos dont have a clue but if they come supplied with those parts use them if not use stock
Old 10-13-2006, 06:20 PM   #7
ravenmaster
No I meant to you have to se them period. I am having a hugely dificult time getting it on
Old 10-13-2006, 06:28 PM   #8
nelly26
thats the problem with supras doing work yourself its not easy pain in ass to correct
Old 10-13-2006, 09:07 PM   #9
ravenmaster
Anyway yes you do.
Old 10-14-2006, 02:22 PM   #10
rnoswal
rnoswal's Avatar
Stock or aftermarket, but yes to either one. If they are direct replacement shocks then they will have the lower spring perch and all you need is a spring compressor and be careful! The rears are easy to get on and off, the fronts are more of a pain, but the same as far as the springs go.
Does that help any? I did mine a while back with no problems. I went with lowered springs all around.
Russ
Rear differential question finaltable MKIII Supra 9 11-13-2007 07:49 PM
Question for someone who has actually seen the outside rear lock mechanism finaltable MKIII Supra 0 10-22-2007 02:44 PM
shock question Jjona5 MKIII Supra 3 02-18-2007 05:32 AM
tranny and rear end question Sisqo94turboprobe MKIII Supra 3 09-13-2005 11:09 PM
