Old 10-10-2006, 11:49 PM   #1
nelly26
nelly26 is on a distinguished road
Talking Engine Change
could any body tell me if it is possible to put a 2JZ-GTE engine into mk 3 supra 92 with all gear box and drive system and wiring and ecu. cheers
nelly26 is offline   Reply With Quote
Old 10-11-2006, 04:43 AM   #2
tone loc
tone loc's Avatar
defintly not same wiring or ecu. tranny might have to be swapped unless you can find the right bell housing. its kind of a project
Old 10-11-2006, 04:59 AM   #3
dcrusupra
dcrusupra's Avatar
This question is asked so many times. Search, you will find a bunch of good info. But since I dont like being told to search myself, I will start you out by saying that you will need to do some rewiring on the harness, you'll need to fabricate motor mounts, slightly modify the firewall to accomodate the rear turbo, and if you want to keep the v160 (6 speed trans), you'll have to make the tranny tunnel wider because it is far beefier than the R154 trans.
New Rebuild
My CarDomain
Old 10-11-2006, 08:02 AM   #4
nelly26
ok cheers i will look into the specs on fitting and sizes and i will let you know cheers if it can be done it will be a project and hair ripping out event cool
Old 10-11-2006, 04:48 PM   #5
nelly26
cheers guys for help but i will not put in that engine because most components are in different place and also need plenty of cash i have another mk3 with knackerd gear box so i will rebuild that engine with a few upgrades and replace all seals and gaskgets and it will be more fun i will do some work myself and get the rest done professional but if you have suggestion on what mods i could upgrade engine with i would appriciated but i must mention i am in uk and it is rhd i am also maybe selling a mk3 car without engine with 2 auto gear boxes if u intrested uk only cheers
change oil pump without pulling engine Jjona5 MKIII Supra 2 02-11-2007 03:29 AM
my mkiv supra wont start after engine change HELP!! gkhawk MKIV Supra 1 08-18-2006 12:40 PM
