Old 09-28-2006, 02:58 PM   #1
redmaro
Default Rebuilding turbo
I have now ordered my turbo rebuilding kit. So my question is, is it easy to rebuild a turbo? I heard something about balancing the compressor wheel. I'm planning on doing it myself. (hopefully)
Old 09-28-2006, 03:58 PM   #2
supra1985turbo
supra1985turbo is on a distinguished road
Wink
I rebuilt my HKS T4 turbo the only problem I had was installing the compressor seal it was a little brass seal with a carbon fiber peice that had to be pressed into the back fo the compressor wheel plate, Need less to say I had to by another seal because I broke the carbon fiber in a bunch of little ity bity peices. I asked the guy that I got it from which he owns his own turbo rebuild shop, how I can install it with out a press, I asked if I could use a c clamp he said that would work and to use a socket that would only touch the brass not the carbon. It took a while but I got it. And make for damn sure you put everything back in its specific place and orintation!!! The rest of the turbo is easy as cake!!!!!!!!!!!!!!!
supra1985turbo is offline   Reply With Quote
Old 09-28-2006, 04:25 PM   #3
redmaro
I hope I dont run into problems rebuilding it. So i guess its not neccesary balance my compressor wheel.
Old 09-28-2006, 04:31 PM   #4
supra1985turbo
Well I'm not sure about that. I didn't but the guy I got the kit from did not say I had to. What turbo do you have?
1985 celica supra upgrading to street/drag well mainly drag. Have complete HKS T4 turbo kit, electronics and all, Getting head port and polish with HKS 264 cams, and port and polished intake with 6 extra injector bungs. Eagle or crower rods? I just bought a 1990 MA70 n/a .
Old 09-28-2006, 07:24 PM   #5
redmaro
I have a stock CT-26 turbo.
Old 09-29-2006, 11:05 AM   #6
supra1985turbo
Wink
That should be easy to rebuild, Like I said in my erlier post make sure you put everything back the way it was. If not you can brake stuff or do damage to the turbo over time.
Rebuilding a turbo 90supra Non-Generation Specific Questions 1 04-28-2008 12:30 PM
