Old 09-07-2006, 04:01 PM   #1
redmaro
Default 2000 Rpm Idle Problem
Every time i start my car the RPM's go up to 2000 or 1500 RPM's. When ever I put it in drive it feels accelerated. But sometimes the RPM's go back to normal around 700 or 800 RPM's. I'm thinking a sensor might be the problem. What could it be???
Old 09-07-2006, 05:09 PM   #2
sd88supra
sd88supra is on a distinguished road
does it rapidly go up and down when cold? you definitely wanna check your TPS. do a diagnostic and get an error code. TPS can be 41 or 51, depending on the problem.
sd88supra is offline   Reply With Quote
Old 09-07-2006, 05:39 PM   #3
redmaro
No it dosent go up or down it stays at high RPM's most of the time.
Old 09-07-2006, 05:44 PM   #4
sd88supra
you probably dont have any air leaks then. id start looking at the TPS. you should be able to get an error code/s.
4runner 7MGE swap idle problem grabber MKIII Supra 3 06-26-2008 11:45 PM
Idle problem again. redmaro MKIII Supra 17 02-10-2007 07:42 AM
Idle problem 1988 Supra non turbo jimwww Non-Generation Specific Questions 3 01-24-2006 03:50 PM
HELP!!!! '87 Supra idle problem Morpho MKIII Supra 0 10-03-2005 02:40 PM
