Old 09-06-2006, 01:41 AM   #1
sd88supra
Default right side lights not working!
my right headlight and tailight arent working! at first i thought it was the bulbs, so i replaced them. but, that didnt work. neither the low nor high beam works on the headlight. i checked the fuse for the right headlight, it was ok but i replaced it just in case. still no luck. i was wondering what other fuses/electrical stuff i should look at.
Old 09-06-2006, 01:53 AM   #2
You need to pull the connector off the headlight and see if you have power and ground.
Dash lights and Side marker lights are not working ebang MKIII Supra 0 04-01-2008 12:35 PM
fog lights not working ?? supra887mgte MKIII Supra 4 06-12-2006 02:35 AM
Dash lights not working! Rommy MKIII Supra 6 05-17-2006 03:55 AM
