Old 08-30-2006, 10:44 PM   #1
sd88supra
Thumbs down pusher vs puller fan
ok, i installed a hayden 14" electric fan in my 87 NA after my fan clutch crapped out. thing is, even the damn fan clutch throws more air and cooled my car much better even without the fan shroud than this shrouded electric fan. i installed it as a puller, since space is scarce in front of the radiator. and yes, i remembered to flip the blade over and reverse the polarity (since they come pusher-ready). as far as spacing, the blades are about 1 inch from the radiator, best i could do withough leaving it all dangly. i dont think it should be closer to the engine, or should it?
my car right now almost seems bipolar. when running continuously, it runs at ideal temp. when idling or in heavy traffic the temp gauge sky rockets. as soon as i step on it it practically falls back down. after driving it around for a while, after turning off the engine you can hear the hot coolant boiling inside, something that never happened before my fan clutch crapped out. but, i dunno if this has anything to do with a bad water pump.
someone please tell me i need a better fan (if the fan is the problem). this is tempting me to go back to the damn fan clutch.
Old 08-31-2006, 07:20 AM   #2
Default I'm cool in the mojave desert.
My car is N/A, so heat is not such a concern as turbo.
The Hayden fan is only rated at 1100 CFM. That is what I am using too. Mounted to the back side of the radiator.
The boiling sound is normal when you shut off engine that is pretty hot. Its boiling the water, and the cap is letting it over into the bottle.
I always have my A/C on here in the desert, so my 2 little factory fans also run, which helps keep it cooler.
I run a 180* thermostat, which won't prevent over heating, but does allow it to run cooler if it can. Better than keeping the temp up to 195* minimum.
I also added a large (12"x15") transmission cooler right in front of the radiator (mounted to it actually), between the radiator and the A/C condensor. I removed the small 3/8" coolant by-pass hose (below the thermstat) and ran hoses out (under the afm)to the new cooler.
I calculated a 40% radiator increase.
It always runs about 1/3 on the gage, and never have the boil over sound anymore.
50/50 antifreeze. New cap.
If I were to ever need a new fan, I would get this.
http://www.jegs.com/webapp/wcs/store...tegoryId=10117
#720-1987...14" 1800cfm.
You may need this. Or do a search on this forum for electric fans others have used.
Old 08-31-2006, 07:16 PM   #3
Cool
my elect fan throws 2950 cfm no shroud
that 1100 isn't going to cut it
Old 09-02-2006, 04:48 AM   #4
That's my point. Gotta have a lot of air moving thru a supra.
What kind / brand are you using??
I may want to upgrade mine.
Also, I removed the rubber hood sealing strip on the body at the firewall. It helps let air out of the engine bay.
But not a good idea if your car has oil leaks, and smokes under the hood.
Old 09-02-2006, 05:37 AM   #5
Isphius
Isphius's Avatar
The reason your car overheats when in traffic is because your not getting any air flow from the car moving lol. If this is happeneing, Your fan is underrated. Get a bigger one! Your fan is there just to cool the car when its moving slow. You dont even need the fan when your going down the highway or just going at least 25 or above. Ive driven around without my fan even on (on my way to get a replacement) And it was fine, Because i didnt stop.
Old 09-03-2006, 02:03 AM   #6
Cool
im using a perma cool and i removed the rubber molding from the engine hood too
after i saw you did it .
it makes alot of sense to me
Old 09-03-2006, 06:01 AM   #7
Isphius
Isphius's Avatar
You also need a shroud of some sort. That helps a lot more than youd think.
Old 09-03-2006, 10:23 PM   #8
sd88supra
Exclamation Update!
ok, i got a flex-a-lite 16" shrouded 2000 cfm fan... it still overheats, but very gradually. the temp gauge doesnt go up until ive been idling for several minutes. works fine for normal driving, even at traffic lights, but its gonna still be overheating under very heavy traffic. and im still getting that coolant boiling. it even looks like it sucked my reservoir bottle (it was almost collapsed) though the reservoir was full.
ive mounted it behind the radiator, as a puller. i didnt have to reverse the blades because it came puller ready, i just had to wire it as a puller.
-2000 cfm
-16" diameter
- shrouded
- puller
what i was thinking though, is that since the fan clutch is farther away from the radiator (and my electric fan is attached to the radiator) it could have something to do with it not having enough room to pull air from. any ideas/suggestions?
Old 09-04-2006, 02:48 AM   #9
h8z2luze
h8z2luze's Avatar
Sounds like you might have a bhg??? Have you replaced the water pump and thermostat? I donno though. I just got a 2600CFM 16" electric fan. We will se how that goes.
Old 09-04-2006, 04:17 AM   #10
sd88supra
i dont see how i could have a bhg, i get lots of compression and no white junk under the cap (or any other bhg symptoms). a bad thermostat and/or water pump would have my car overheating even when driving fast. its air im not getting into my radiator, i just dont understand why.
Electric Fan? mkiiisupra MKIII Supra 24 06-18-2010 08:26 PM
crank shaft pulley puller supramacist MKIII Supra 30 04-18-2007 02:27 AM
