Old 08-11-2006, 06:17 PM   #1
resurrecta
resurrecta is on a distinguished road
Default 3.0T Vs 2.5Bi-T
Well, I just recently saw a 2.5 Bi-Turbo MKIII, and I have a 3.0T which has less HP. I was wondering, cause I'm a noob on turbo's... Can it be done to set-up a bi-Turbo for my own MKIII? And what tweaks need to be done?
resurrecta is offline   Reply With Quote
Old 08-12-2006, 06:10 AM   #2
Supra2NR
Supra2NR's Avatar
on a few post before
sumbody said that
sumone had a custom turbo downpipe to accomodate two turbos
im guessing you have to change the compression rate
maybe bigger injectors? not sure tho
but dont try any of these upgrades unless you have the help of a dyno
dont wanna pay for a custom job jus to ruin you engine
Old 08-12-2006, 03:55 PM   #3
kwnate
SP58GT
It would be cheaper to just upgrade the single turbo you already have.
Nate
Old 08-13-2006, 02:17 AM   #4
resurrecta
money isn't an issue, but which one is more powerful in the end?
Old 08-13-2006, 03:05 AM   #5
dcrusupra
dcrusupra's Avatar
A big single turbo is usually faster in the end. Thats y most of the MKIV guys usually go single.
New Rebuild
My CarDomain
Old 08-13-2006, 09:44 AM   #6
Supra2NR
Supra2NR's Avatar
question about twins
are the inline turbos the same size?
if not which one is bigger the front or back?
shouldnt they make a small and a big one
and does any company started making those variable turbos
bmw has developed that technology
it a big turbo with movable fins around the turbines
which closes in low speeds/rpm and opens in high speeds/rpm
so in low speeds it can spool up quickly without lag
and in high speeds it wont choke on exhaust
Old 08-13-2006, 11:13 AM   #7
f00g00
The front turbo is for the first 3 cylinders and the rear turbo for the last 3 so they are the same size.
Old 08-13-2006, 03:09 PM   #8
resurrecta
yeah standard CT26's... that's why I wondered... cause I can get performance parts very easily through a friend that has a sponsored deal. So I was kinda wondering to get 2 big turbo's in for max performance. Dunno if it would do any good though...
Old 08-13-2006, 10:20 PM   #9
ZauggIt1
ZauggIt1's Avatar
ZauggIt1 is on a distinguished road
Yes someone does make these turbos, the only thing is that its for pickups. Banks power makes them , i seen them on an episode of Extreme 4x4. They are just plain out nuts. Im sure someone could figure out how to put it on a supra though.
Drive it like you stole it!!!
ZauggIt1 is offline   Reply With Quote
Old 08-13-2006, 10:40 PM   #10
Supra2NR
Supra2NR's Avatar
the big question with variable turbos is:
how do you control the fin when opening and closing?
is it electronically controlled?
or by just the mass of air coming in into the turbo?
