Old 08-10-2006, 02:49 AM   #1
redmaro
Default CT26 Upraded Turbo?
Few Questions
My current Turbo has an oil leak and it seems to be the O ring. Would buying a diffrent Turbo fix my problem?
What things will I have to change If I buy an upgraded turbo?
Will I feel a noticiable diffrence if I buy an upgraded turbo?
Will I be in the low 14's if i buy a upgraded turbo?
Help a newbee please.
Old 08-10-2006, 04:56 AM   #2
marc
the boost on the turbo and how high it boost depends on the turbo and if u have it set to boost high via a boost controller. um if ur planning ot upgrade ur turbo either have ur head retorqued down, or what is more highly recommeded; get a metal head gasket and machine the heads flat. dont get anything ridiculously big if its the only upgrade u have so far. if ur tryin to go big make sure to upgrade ur exhaust. and u probly want to get a new intercooler
nothing but the best
-mods- so far
K&N intake fipk
3" megan downpipe
3"turbo elbow
4 washers on the wastegate
highflow cat
short shifter
many more upgrades soon
Old 08-19-2006, 08:43 PM   #3
redmaro
will buying a turbo fix my oil leak problem?
Old 08-24-2006, 04:47 PM   #4
grygst76
grygst76 is on a distinguished road
yes, if it is leaking buying a new one will of course, or repair the one you have.
grygst76 is offline   Reply With Quote
Old 08-24-2006, 11:07 PM   #5
Isphius
Isphius's Avatar
Yeah, Just get a new ct26 or have yours fixed. It is good untill about 12 or 13 psi. If you want some fun out of it, do the standard intake/exhaust/manual boost controller, And turn it up till you hit boost cut then back it off a little. You also might want an aftermarket boost gauge when upgrading. Boost cut is about 12 psi ish.
