Old 08-03-2006, 09:51 AM   #1
bigchalk
bigchalk is on a distinguished road
Default compression loss
i bought my 1989 supra and was told it ran but doesnt hold compression in 2 cylinders i am hopeing its just a head gasket any ideas
bigchalk is offline   Reply With Quote
Old 08-03-2006, 02:03 PM   #2
Isphius
Isphius's Avatar
Headgasket, Valves bent/broke, Rings beat, Broken piston...Could be lots of stuff. I bet its the headgasket tho. Do a leakdown test, And see how fast it goes. If its really fast, Probably a broken metal part. I wouldnt run the car like this. Probably fragments in the cylinders, and that is not good! I got a spring in my gokart motor once, Ill show you a picture of it later what it did lol.
Old 08-04-2006, 04:32 AM   #3
marc
ive seen dismembered engines where stuff has gotten into the cylinders..GAME OVER for that engine. u can see the imprint of where the piston head hit the object or watever was in it. ive seen half of a screw indented into an engines piston. and ive also seen water damage to pistons. the whole rod was snapped because water got into the cylinder and couldnt combust so the rod has too much pressure oushing back on it as it was thrusting and it snapped. crazzzy stuff.
nothing but the best
-mods- so far
K&N intake fipk
3" megan downpipe
3"turbo elbow
4 washers on the wastegate
highflow cat
short shifter
many more upgrades soon
Old 08-04-2006, 05:41 AM   #4
tone loc
tone loc's Avatar
how do u do a leak down test??
Old 08-04-2006, 12:41 PM   #5
rnoswal
rnoswal's Avatar
A leak down test puts air into the cylinder then the guage shows if there is a pressure loss and if so, how much pressure is lost during a set time. All cylinders are going to leak some though. You can sometimes hear the air escaping through various parts though. Through the intake then probably an intake valve and same with the exhaust. If you can hear air coming through the oil filler cap then it is most likely worn out rings, if you get bubbling in the radiator, well that pretty much shows a gasket problem and if you can hear air coming out the sparkplug hole next to the pressurized one then it is again the gasket.
I'm sure more out there have more info, but probably a shop that you trust and would let you see what's going on would be best as the guages might be expensive.
Russ
Old 08-04-2006, 03:32 PM   #6
Isphius
Isphius's Avatar
Yeah, Its a good idea to let a pro do it. But you can get a compression tester, thats pretty easy to use.
Compression check when cold gottadiesel MKIII Supra 3 02-26-2009 07:24 AM
Compression and Block Tests mrnickleye Supra FAQ 0 01-29-2007 03:49 AM
Just did compression test...Help with oil pressure! 2JZEFINI-17 MKIII Supra 1 11-06-2006 12:06 AM
looking at a 90 turbo with compression problems jtitzer56 MKIII Supra 1 09-23-2006 05:27 PM
Massive power loss 808Supra MKIII Supra 3 05-24-2006 02:58 AM
