Old 08-01-2006, 01:35 AM   #1
Deputy99
Deputy99 is on a distinguished road
Default fuel pump relay buzzing
OK just rebiult my 88 non turbo supra. hooked everything back together and when i connect it to the battery i get a buzzing from my fuel pump relay. is it fucked or did i hook something up wrong
Deputy99 is offline   Reply With Quote
Old 08-01-2006, 10:58 PM   #2
Deputy99
Ok I got a new relay from the autowreckers and it does the same thing. anyone have any ideas?
Old 08-13-2006, 08:31 PM   #3
Deputy99
ok so i bought another relay and a resistor and i still get the buzzing when i connect the battery. Does anybody have any clue what so ever??? I am dying over here i checked the resistance and it all checks out as per what the repair manual says. so it must be something else doing it?? i tried searching the forums and cant find any answers. I am on my knee's begging someone has to know the answer
thanks Jeff
Old 06-19-2008, 11:29 PM   #4
Geebs
Geebs is on a distinguished road
Hey, Did you ever get this figured out? Mine is doing the exact same thing. Please let me know!
Thanks!
Joel
Geebs is offline   Reply With Quote
Old 06-20-2008, 02:20 AM   #5
CyFi6
For some reason whenever i jumper the fuel pump in the diagnostic box, my relay buzzes, but when i run the car it does not. Im not sure why, but maybe it can help you figure out your problem.
Old 06-24-2008, 01:40 PM   #6
suprabahamut
I have a 88 non turbo too, does yours crank up. Mine buzzes but cranks, as long as it cranks its is fine with me.
Old 06-25-2008, 05:39 PM   #7
solomonsterous
solomonsterous is on a distinguished road
I have the same problem with my 92 Supra Turbo.
Has anyone figured it out yet?
So far, I know the circuit containing the Fuel Pump Relay also contains the Circuit Opening Relay ( located on the passenger side kick panel ), and EFI Main Relay. One of the VSV below the intake may be related too.
3 things click simultaneously once, when I connect the battery then the Fuel Pump Relay buzzes.
solomonsterous is offline   Reply With Quote
Old 06-27-2008, 02:58 AM   #8
abhattan
abhattan's Avatar
Usually that "buzzing" noise is the relay opening and closing extremely fast. That means that it is not getting the correct amount of voltage or current. It might be a little difficult, but check the voltage going into it on the coil part of the relay. If it's too low, that's your problem. But the car has to be running. I somewhat of a current draw in my car which is similar. My dome lights come on whenever it seems that the car has enough juice. The buzzer changes tones as the voltage increases as well. I probably have current draw somewhere, but it's not bothering me right now. Let me know what you come up with.
'91 Turbo Targa 5 Spd.
'87 Corolla GT-S 5 Spd
'91 Accord Daily Driver 5 Spd
MSD fuel pump? redmaro MKIII Supra 6 08-24-2007 04:09 PM
Fuel Pump Relay noise GremlinMKIII MKIII Supra 12 06-19-2007 08:27 AM
fuel pump relay Supra2NR MKIII Supra 4 05-18-2007 11:35 PM
