Old 07-27-2006, 04:58 PM   #1
Dejvid1785
Dejvid1785 is on a distinguished road
Default Successful 7M-GTE swap into NA Supra
Has anyone in here swapped a 7M-GTE into a NA body successfully? I would like to get in contact with anyone that has and ask some questions.
88 Targa: Exhaust, Headers, Intake
Dejvid1785 is offline   Reply With Quote
Old 07-27-2006, 07:43 PM   #2
gomezmk
I did a jdm swap 7mgte into a na body on my 87 supra.There's a good site on doing a swap at mkiiitech.com.
Old 07-28-2006, 04:29 AM   #3
Dejvid1785
I know about that site i just thought it would be better if i could hear from someone that has actually done it themselves. What was the hardest part? If you don't mind kinda recap what all you had to do.
Old 07-28-2006, 06:51 PM   #4
CzA
CzA is on a distinguished road
I am actually in the middle of doing the swap. I just took both engines out, and put the gte in the n/a car. Now its all about hooking all the things back up. What’s your question, ill try to answer it.
CzA is offline   Reply With Quote
Old 07-30-2006, 04:51 AM   #5
gomezmk
the hardest part of the whole swap was find all the sensors need to complete the swap such as a air flow meter, hac sensor, ecu, wiring harness, ignitor and intercooler piping which is cheapest to custom make, other than that, it was pretty much simple. I bought most of my stuff on ebay but you just have to take the time to wait for the best price. Also for the oil cooler, I just bought a b and m tranny cooler from summit.
Old 07-31-2006, 02:29 AM   #6
Dejvid1785
How did the re-wiring go to make the tach work? What else was really hard? Did you have to use the turbo drive-shaft? Will the NA LSD be alright cuz apparently there is a difference.
Old 07-31-2006, 03:29 AM   #7
gomezmk
to make the tach work, you have to pull out the cluster and take out the tach gauge, behind the tach is a small little box with resistors on them. On mkiiitech they explain which resistors have to be cut out and the ohm value to replace them with, I soldered my on. And for the driveshaft, I stuck with the na 5-speed so I left the drive terrain alone and so far it's worked fine. My na came with lsd when i got it.
Old 07-31-2006, 03:35 AM   #8
Supra2NR
Supra2NR's Avatar
one question
how much did all this run you?
Old 07-31-2006, 04:49 AM   #9
gomezmk
including a jdm engine it was about 2,500 dollars.
Old 07-31-2006, 06:08 AM   #10
Supra2NR
Supra2NR's Avatar
not bad,
how much was the engine itself,
and when you got the engine, what else did you get
what else should i ask to come with the engine
all i can think of right now is the intercooler , and the ecu
u said u used the same tranny right?
what did you have to do to make it work
did you customize anything to make it fit ?
and how long did it take to get it done?
85 Supra Swap (Help) Guillen_Don MKII Supra 2 03-01-2008 02:15 AM
89 Supra Turbo w/1JZ Swap Problems Donnies Foreign Car Non-Generation Specific Questions 1 02-02-2006 05:03 PM
