Old 07-23-2006, 07:34 AM   #1
whitequasimodo
whitequasimodo's Avatar
whitequasimodo is on a distinguished road
Default new engine Q
im thinking of dropping a new engine into my 88 turbo, any guess on what engine i should get. is it possible to to find an engine to go twins with? I don’t think so, but i think you guys and gals can prove me wrong. post some sites thanks ..
whitequasimodo is offline   Reply With Quote
Old 07-23-2006, 03:01 PM   #2
dcrusupra
dcrusupra's Avatar
1jz is a twin turbo engine you can get pretty easily. They only came on the non-american cars. Only thing with that is you'll need new engine mounts and you'll need to extend the wiring harness about 18" or so. Unless you want to convert your car to RHD. Probably not as easy as extending the wiring harness but would be pretty cool. The manual 1jz engine/tranny are harder to find than the automatic ones, and more expensive. So if you want to use your existing transmission, you'll need the 1JZ bellhousing. Only downside of this engine is the torque. Upside is a higher redline.
Then theres the 1g-gte. Also a twin turbo engine, but it has less power stock than the 7m-gte does stock.
New Rebuild
My CarDomain
Old 07-23-2006, 05:26 PM   #3
sharkn
sharkn is on a distinguished road
how hard will swaping with a 2jz be i was thinking of eventually doing that with mine
sharkn is offline   Reply With Quote
Old 07-24-2006, 06:14 AM   #4
Supra2NR
Supra2NR's Avatar
itll take talent to do it,
so basically you need,
money
time
another car
while its being workd with
but go for it tho
i wanna do too, im jus short of money (really short)
