Old 07-20-2006, 02:37 PM   #1
Tortilla
Tortilla is on a distinguished road
Default Power Failure?
On the way to work this morning, my radio started going off and coming on in a split second. did this twice, when i got to work and shut the car off the power locks wouldn't work. The car doesn't start, it's totally dead. Anyone have any ideas? It's been running great, no signs of any electrical problems up till now. I popped the hood and the cables on the battery are tight and don't look to be corroded really. Just wondering if anyone has any clue on what this could be so maybe I can get it fixed during my lunch break.
Thanks
Tortilla is offline   Reply With Quote
Old 07-20-2006, 03:33 PM   #2
SupraSaver87
SupraSaver87's Avatar
Talking Beat You All!!!
YES!!! I get a FIRST POST!!!!
LOL....alright, well that sounds like a loose ground wire. It has been said that you should check the grounds from the battery, and the grounds from the firewall to the block...I don't know of the other ground wires...but yeah, it sounds like a loose ground wire.
Just play around with those ones, maybe get out a trusty ratchet, and then tighten up all of those. Hope that helps you out, and all works when you are done checking.
Old 07-20-2006, 04:13 PM   #3
Tortilla
thanks for the quick reply. on my lunch now so after i eat something i'll go back to work and try that out. It does sound like something is loose since the radio went off and on twice in the span of a few seconds.
Old 07-20-2006, 07:10 PM   #4
theWeezL
theWeezL's Avatar
sounds to me like your alternator died
____________
Old 07-20-2006, 09:35 PM   #5
SupraSaver87
Default Question
If it was his alternator, wouldn't he have had an engine warning light go off? I would HOPE that the alternator current is being monitored by the ECU. However yeah, your right theWeezLe, it could be that as well....but both would have similar symptoms, however if he could provide all the info he can on this, then we could help out more.
As I would see it if the alternator died..specially while he was driving, the warning light would come on, probably with a "No Alt Current" code. And his engine would have still drawn from the battery...till it was dead. Either way, the best way to deal with this is to check your grounds, and then if those are fine, and your problem not fixed...then you should have the alternator checked out.
Tortilla, you either have a VERY simple, and no money fix...or your looking at around $100 Canadian...for just a core...or something like that. (The $100 is for the alternator...however I have seen an 80 AMP (opposed to the 70 AMP stock one) for as much as $250 US!!!)
Old 07-20-2006, 09:52 PM   #6
sharkn
sharkn is on a distinguished road
yeah its the ground mine did it a couple weeks ago same exact thing the battery was too small for the battery tiedown and moving back and forth broke the ground from the terminal..
also there is a ground by the starter easiest to get to from under the car
sharkn is offline   Reply With Quote
Old 07-20-2006, 10:47 PM   #7
Tortilla
ya i don't think it's the alternator. both the ground wire by the battery and the ground wire on the firewall were good. I will check the one by the starter though, thanks. The reason I don't think it was the alternator is it went from running with air conditioner, and raidio going fine till when i turned it off i had absolutely no power. power locks use minimal power and that's how i found out there was a problem, when i went to lock up the car.
Old 07-20-2006, 11:24 PM   #8
dcrusupra
dcrusupra's Avatar
Did the red battery light go on before it died?
New Rebuild
My CarDomain
Old 07-20-2006, 11:58 PM   #9
Isphius
Isphius's Avatar
Yah, The red battery light turns on if your voltage goes lower than about 12.5 volts. Does any power come on or just no start? it could be a loose wire inside the alternator tho, Or somewhere along the positive/negative cables. The car needs a complete circuit to turn the fuel injection on too, so you cant even push start it. Just replace the positive and negative cables. They shouldnt be that much. There kind of a pain to reach tho. Also look at all ure fuses and breakers in the box next to the battery.
Old 07-21-2006, 12:08 AM   #10
sharkn
i forgot there is one by the crossmember on the ass end of the tranny also we'll thats where mine is but it doesnt look like it would be affected by wear unless something hits it going down the road..did you check there?
Aftermarket shifters for R154 trans MKIII? Boombastic Exterior , Interior, and Detailing 4 08-11-2010 04:28 PM
getaway in stockholm... (i think thats how you spell it) kelogg Road Racing & Autocross 3 06-03-2008 10:53 PM
only starts by jump start ItsnotmySupra MKII Supra 6 04-27-2008 03:14 AM
MEET UP's TEAM_Bastos Drifting 0 03-02-2006 09:09 PM
