Old 07-08-2006, 02:14 PM   #1
supra8990
supra8990 is on a distinguished road
Default please help me with a problem.....
I know there are many posts about BHG but i have looked and i cant find anyone with this problem. ok i start the car it starts great no smoke perfect, i drive it its fine if i dont get on it, when it warms up and i start to get on it, it will puff some white smoke when i stop and drop the rpm's only when i stop, it does not smoke all the time? can anyone help me? not losing coolant either, oil is not milky
supra8990 is offline   Reply With Quote
Old 07-08-2006, 09:29 PM   #2
travsparky
travsparky's Avatar
travsparky is on a distinguished road
Default dont worry
Dont worry about the smoke. if its a turbo supra then its supposed to do that. mine does it. if no smoke appears at all then you have a problem. if the smoke is white then no problems either. when you see the puff of smoke it means the turbo('s) are warmed up. do you by chance know haw to connect the sppedo cable?
travsparky is offline   Reply With Quote
Old 07-08-2006, 11:56 PM   #3
supra90turbo
supra90turbo's Avatar
Miss Information? Paging Miss Information... Has anyone seen her?
No car is supposed to smoke. Stop posting.
If it's white, it's coolant.
If it's blue, it's oil
If it's black, it's fuel.
Because it's so little, it may not appear that you're losing any coolant, but you are.
Do a block test. Napa sells a kit as well as many other stores.
Old 07-09-2006, 03:52 AM   #4
OmeGa
OmeGa's Avatar
OmeGa is on a distinguished road
This is exactly what my car is doing, how would you fix it though?
OmeGa is offline   Reply With Quote
Old 07-09-2006, 05:20 AM   #5
supra90turbo
Perform a block test, compression test, and leakdown test.
You'll find the problem somewhere.
Pressure test your cooling system
Old 07-09-2006, 09:39 AM   #6
OmeGa
OmeGa's Avatar
http://www.cygnusx1.net/supra/techtip/bhgfaq.html
This helped me out a lot.
Old 07-09-2006, 01:27 PM   #7
IHateHacks
IHateHacks's Avatar
Nice job supra90turbo, I couldnt have said it better!
Old 07-09-2006, 05:21 PM   #8
dcrusupra
dcrusupra's Avatar
Damn Kurt, ur mean. Lol.
New Rebuild
My CarDomain
Old 07-09-2006, 07:39 PM   #9
rnoswal
rnoswal's Avatar
Well I do hate to tell you this but even though no car is supposed to smoke, the turbo does and will. It is that crappy engine ventilation system that does it. Eventually you get oil accumulated in the turbo tubing and that will eventually get sucked up and get burned, causing SMOKE! That is why so many of these guys buy the oil catch can from JAZ, so they have a place to vatch the oil before it gets burned. If you have all stock components then you will get that puff of blue, even though these guy hate to admit it.
Russ
Old 07-09-2006, 09:39 PM   #10
travsparky
travsparky's Avatar
Default i found the problem
sorry bout previous post, my bro thought he was smart. the problem that mine had with the smoke was that the valve seals had become hard (cause they were the originals from 1991) and that lets oil trough wich gets burnt. all i did was change the seals and voila no more smoke.
