Old 06-20-2006, 01:00 AM   #1
White87Turbo
White87Turbo is on a distinguished road
Default Idle Position Sensor Problem
If I have a Idle Position sensor problem would that cause my turbo to no spool, over spool, or cause my Supra to just turn off while i drive it. If anyone knows what this would do if it doesnt work.
White87Turbo is offline   Reply With Quote
Old 06-20-2006, 04:27 AM   #2
damdog05
damdog05's Avatar
i had a problem with my TPS and all it did was raise my NOx output so i didnt pass emissions. the cutting off sounds like an intake problem. maybe you afm, or the intake tube from it to the throttle bottle. i know from experience that if that disconnects that the engine shuts off
My cars:
85 Trans Am- Ehhh- Gone
83 Rx7- Much Better- Gone
86.5 Supra- Love- Not Gone
Old 06-20-2006, 04:32 AM   #3
White87Turbo
I checked to make sure that the intake wasnt clogged and i thought that the AFM could be the problem and i just bought a new one saturday and it didnt make a difference. Its when i make boost that it starts to hesistate and not want to go. I moved the idle sensor a bit and then it worked for a trip down the street and on the way home it didnt.
Old 06-20-2006, 04:38 AM   #4
damdog05
damdog05's Avatar
ok. well the turbo is out of my knowledge range..i have an n/a. hope you find the solution
My cars:
Old 06-20-2006, 05:38 AM   #5
joel w
joel w's Avatar
Check your codes first and let us know what you find..
http://www.cygnusx1.net/supra/librar...fi/FI_023.html
Try describing your problem better..
1) Is your turbo not spooling or is it over spooling?
2) describe when and how the car "turns off" on you.
For example: (after starting is a given), after boosting, after you let off the gas at the stop light, when the car is cold, when its warm? More info please..
TPS (throttle position sensor) or ISC (Idle speed controller), both should not cause boost issues but can effect idle and or base timing/performance..
Finally, Idle Set! scruffboy Non-Generation Specific Questions 6 01-16-2007 02:39 PM
Idle problem 1988 Supra non turbo jimwww Non-Generation Specific Questions 3 01-24-2006 03:50 PM
