Old 06-19-2006, 04:34 PM   #1
dedbonz666
dedbonz666 is on a distinguished road
Exclamation Can't get this thing going.... help please
I just got an '87 non turbo. It was choking for air and i changed the AFM. Noy it seemd like it's missing. I've done plugs, cap, rotor, tried timing, now I'm thinking igniter? I'm not getting any relevant fault codes, Any ideas? TPS maybe? I'm going to do a fuel filter tonite, any help would be appreciated. Thanx,
Bert
dedbonz666 is offline   Reply With Quote
Old 06-19-2006, 05:05 PM   #2
theWeezL
theWeezL's Avatar
Timing? dirty fuel injectors?
other than what you already mentioned those things come to mind.
____________
Old 06-19-2006, 05:45 PM   #3
dedbonz666
Default Injectors
Injectors Are A Thought, I Cant Get It To Go In Time At All, Heat Is Definitely An Issue... Easy Way To Check Injectors?
Old 06-19-2006, 06:11 PM   #4
theWeezL
theWeezL's Avatar
I dont kow of any great way to "check" your injectors but you could take it to a shop that does injector cleaning on the car. They essentially tap into the fuel system and spray a concentrated cleaner into the fuel system while the car is running and it loosens and burns off all the deposits. Ive seen it done, and it seems to cure most injector issues pretty quickly. The shop I go to for specialized work like this charges $85 for that service.
____________
Old 06-19-2006, 06:21 PM   #5
ddmcse
ddmcse's Avatar
Cool
air flow meter got whacked when you installed the new air filter ??
check the connection on the AFM
300+ RW HP Dyno run,
Blown HeadGasket info
My Supra KiXGaS
Old 06-19-2006, 06:39 PM   #6
dedbonz666
Unhappy
Air Flow Meter Seems Good, The Car Was Starving For Air Before, But I Seem To Have Corrected That. Going To Blow Out The Spark Plug Ports Tonite, Just To Be Sure They Are Dry. Piece By Miserable Piece I Guess, My Wife Just Wants To Drive Her Shiny New Supra...
Old 06-20-2006, 12:10 AM   #7
jfunez
jfunez's Avatar
dont forget a posible bad ignition wire..
Old 06-20-2006, 10:10 AM   #8
f00g00
Default Injector seals
If you end up removing the injectors change the seals. There are 3 per injector. Over time they will harden so you end up with a too lean condition when they start allowing air to enter. I burned a set of rings for letting them go too long in a lean state. I had codes 25 and 26 pop up now and then and when I had to change motors I had them install a JDM motor so they used my old injectors and it ran so bad because the seals were hard as a rock that it engine just sat there and sputtered and shook. When I set a bottle of water on my engine it looked like an ultrasound bath in the bottle.
Im getting code 25 and 26 again now and am going to change my seals later tonight when its cooled down some.
Old 06-20-2006, 02:58 PM   #9
dedbonz666
yayyyy... getting closer, had a bad spark plug, two suspect plug wires, and I think the measuring device in the AFM may be dirty, going to try some more tonite. Drove it last night and it ran like a raped ape, this thing is quick!
Old 06-20-2006, 11:15 PM   #10
jfunez
jfunez's Avatar
raped ape.... thats a new one..!!
I washed my engine. Bad thing to do! AaronsSupraMKIII MKIII Supra 8 07-26-2007 07:06 PM
Have Some Problems, need direction I thought it was a fuel thing James87n\a Non-Generation Specific Questions 2 05-26-2007 04:57 AM
this ebay thing? newbsupra MKIII Supra 4 07-20-2006 10:01 PM
Saw the strangest thing White87Turbo Off Topic Forum 2 05-20-2006 08:46 AM
