Old 06-01-2006, 12:35 AM   #1
christutecky
christutecky is on a distinguished road
Default Hatch Rattle...anyone else? any fix?
Hey, My hatch rattles, and it seems to be getting worse....is there any adjustments I can make to the ltaching mechanisim to make it hold tighter and stop the rattle?
Thanks
Chris
christutecky is offline   Reply With Quote
Old 06-01-2006, 01:50 AM   #2
razerback121
razerback121 is on a distinguished road
When does it rattle? idle? closing, acc., dec.?
razerback121 is offline   Reply With Quote
Old 06-01-2006, 01:51 AM   #3
TONY!
TONY!'s Avatar
Well I have removed a hatch from one of these cars before.
They are held on by two hinges.
I have pics that come can be useful because I sell parts. heh
Is is possible that the bolts are not on tight enough on that hatch.
How about where the end of the hatch latches on to the back of the car--maybe that needs lubing?
Is it possible that someon could drive the car for you while you sit in the back of it and figure out where it is coming from?
That is all if it is indeed from the hatch, and not something else.
_____|_____
_________________
/OO]====(W)====[OO\
[___________________]
[ [O] ///______\\\ [O]_]
Old 06-01-2006, 05:42 AM   #4
f00g00
Default Rubber stops
Also check the little rubber stops on either side mounted towards the bottom of the hatch on the car. The screws seemed to be torqued down to 100 foot pounds. I stripped mine trying to take them out but if the rubber is worn as mine are they will let the hatchback wobble which could be causing the rattle.
Old 06-01-2006, 08:52 AM   #5
G-string
G-string's Avatar
G-string is on a distinguished road
Yeah my hatch raddles aswell untilli go fast enough on the highway the spoiler holds it down, lol so just drive faster
to much pizza makes me feal sick
G-string is offline   Reply With Quote
Old 06-02-2006, 01:12 AM   #6
christutecky
Default hatch rattle
It just rattles when I hit potholes, or am driving on a less then perfect road surface, but I mean its pretty loud and obvious. I'll check the bolts and such....When the hatch was open, I gave it a little shake, to see if the hinges were loose, they didnt seem to be, but I'll look again...thanks
Chris
Old 06-02-2006, 12:58 PM   #7
rnoswal
rnoswal's Avatar
I am thinking that the rubber stoppers have worn out and the hatch is now sitting too low and the latch is now loose and rattling. Possibly the rubber seal around the hatch is worn too, but you can adjust the latch and have it pull the hatch down tighter if you need to.
Russ
Old 06-03-2006, 02:53 AM   #8
You are not gonna be able to adjust the hatch. You can still get those rubber stops, and those stops on each "side". All should be in contact with the hatch when it is closed.
That hatch weighs a ton, and jiggles alot on the road.
I have had some success, for the last 3 years, with a tiny dab of vaseline smeared on all those stops. Mine's starting to rattle a little now, so I'm going out right now and add a little.
OK, I'm back. I'll let you know in a couple of days if it's still working.
Also, I was thinking that if it still rattles, I'll try adding a couple of layers of tape on the hatch at the places the stops rub. This will take up any clearance, and may help.
Hood & Hatch Supports mrnickleye MKIII FAQ 2 04-16-2009 01:37 PM
Rear Hatch Won't Open-HELP! Benesesso MKIII Supra 4 07-21-2008 12:37 PM
Hatch Problems AZN_Pride MKIII Supra 6 07-27-2006 03:56 AM
