Old 03-06-2005, 04:48 AM   #1
White91T
Guest
Posts: n/a
91 Turbo running 9 psi.
Two or three minutes after buying full tank of gas, engine shudders and dies while under full throttle at 4500 rpm.
Engine will not restart or run without at least 1/4 throttle. Barely got it home shuddering and shaking the entire way. (two blocks) Turbo kinda spools but acts as if someone were flooring and releasing accelerator rapidly.
Intercooler pipes all connected.
No obvious air leaks that i could find.
Spark to the back two plugs. (i haven't checked the others yet)
No computer codes.
fuel pump sounds normal (haven't checked pressure yet)
Bad gas or coincidence?
Where should i start?
What cause is most likely?
Should i check for hidden intake leaks with some propane?
thanks
Old 07-10-2006, 12:36 AM   #2
frostburn
frostburn is on a distinguished road
you need to put injector cleaner in ur gas tank, would be my guess
frostburn is offline   Reply With Quote
Old 07-10-2006, 12:42 AM   #3
blitzmkiii
blitzmkiii is on a distinguished road
Yea i would think dirty injectors or a few bad injectors
1987 5-speed Turbo, JDM 7M-GTE, K&N air filter, 3' straight exhaust, Blitz BOV, Upgraded CT26 Turbo, 3' Down Pipe, NGK Iridium Spark Plugs And Wires, Megan Racing Strut Bar
blitzmkiii is offline   Reply With Quote
Old 07-10-2006, 02:46 AM   #4
theWeezL
theWeezL's Avatar
yeah those could be the problem but I would be slightly worried about your Turbo system as well. Boost leak? cracked hose? having to peddle it that much sounds more like air starvation rather than fuel.
But since you just fueled up it is a possiblity that you might have some bad gas...water in the lines? plugged fuel filter?
____________
Old 07-10-2006, 02:21 PM   #5
IHateHacks
IHateHacks's Avatar
Post
Umm besides the fact he is not a registered member, this thread is over a year old.......
Old 07-10-2006, 05:26 PM   #6
theWeezL
theWeezL's Avatar
Bleh who dug this post out of the the mothballs...Frostburn you dork!
ohh well, just a mental excercise I guess
____________
Old 07-10-2006, 11:10 PM   #7
jfunez
jfunez's Avatar
ha ha ha !!!!!
the resucitator .....
Old 07-11-2006, 12:17 AM   #8
h8z2luze
h8z2luze's Avatar
lol anyway he has water in the gas.
Old 07-11-2006, 12:50 AM   #9
frostburn
lol didnt realize the date was tired n lookin through old posts, but i guarentee he just needed injector cleaner or a new filter
Sick Vid For All You Mkiii Lovers tyron MKIII Supra 7 06-27-2010 03:13 PM
sick supra Mikek MKIII Supra 1 03-23-2007 01:25 AM
i need help! my baby'z sick :( 89supra323 MKIII Supra 5 02-27-2006 09:24 PM
My Supra is sick, please help me! 89_Supra MKIII Supra 3 09-06-2005 01:42 AM
My Supra's acting weird Supra91_ishot Non-Generation Specific Questions 1 07-08-2005 04:22 AM
