Old 07-21-2010, 03:19 AM   #11
The cold start injector is not as precise a device as the other injectors. A thorough cleaning with carb cleaner (not brake cleaner) or toluene is often all that is needed if the injector's coil is in good shape. If that's all it needs it's a cheap fix... if not you're only out 10 minutes and $5.
Old 11-07-2010, 02:14 AM   #12
bassboy3313
bassboy3313 is on a distinguished road
what does the cold start injector look like and where is it located? My car takes a bit of cranking before starting these passed couple cold mornings and days.
bassboy3313 is offline   Reply With Quote
Old 11-13-2010, 08:32 PM   #13
Top center of the intake plenum on the N/A and bottom center of the intake plenum on the turbo. See the second page. http://www.cygnusx1.net/Supra/Librar...ection=FI&P=77
cold starting problems Cjanik MKIII Supra 9 08-02-2008 06:50 PM
Cold Start System atsomepoint Non-Generation Specific Questions 1 08-16-2007 03:31 PM
hassle starting MK2 When a little cold outside BrockTMK2 MKII Supra 2 08-04-2006 05:54 AM
my car only start when cold? supfoo514 MKIII Supra 3 06-04-2006 11:22 PM
Cold Start problem bigal0043 MKIII Supra 4 10-12-2005 02:40 PM
