Old 05-01-2006, 11:58 PM   #1
87supraguy
87supraguy is on a distinguished road
Default wont stay started
hey just got my car out of storage on tuesday (87 n/a 5 speed) she ran and drove fine untill about saturday night. saturay night she would start but than would die shortly after unless i held my foot on the gas. than today i went to work and even with the pedal to the floor she wouldnt do anything for a few seconds than shed finally slowly rev. had to leave my car at work today didnt want to get stranded. me and our maintence guy wen through all the vacuum hoses and everything seems to be ok unplugged plug wires one at a time but everytime he unplugged one it made no difference which worries me too. Plus i did the diagnostics and code 22 flashed (temp sensor??) any one experience any of these problems or might know what it could be thanks.
87supraguy is offline   Reply With Quote
Old 05-02-2006, 11:43 AM   #2
f00g00
Default Coolant temp sensor
Your ECU is telling the truth. My 87 N/A car had the same problem, poor running, code 22. I reseated the plug on the coolant temp sensor (two pin plug on thermostat housing next to the timing belt cover) and it worked for awhile. My ECU harness is basically brittle from running in a desert environment for over 10 years so I had to splice in two new wires and the problem was solved. The temp sensor is probably OK, it should read between 200-400 ohms when its warmed up.
Old 05-03-2006, 12:24 AM   #3
87supraguy
even with the code 22 my temp gauge still works. plus when i start it the engine light comes on and it runs fine. after about 10 min it shuts off than runs like crap
Old 05-03-2006, 01:42 AM   #4
mkiiisupra88
mkiiisupra88's Avatar
mkiiisupra88 is on a distinguished road
it could be ur MAF....same thing happened to his car....is intake kinda...fell apart after the MAF and it wouldnt let the motor run...easy check...
mkiiisupra88 is offline   Reply With Quote
Old 05-03-2006, 03:09 AM   #5
87supraguy
cousin said it might be my oxygen sensor. get a new one on thursday. how do you test/check your maf?
Old 05-03-2006, 03:48 AM   #6
f00g00
Default temp guage
The temp gauge sender is a different sensor located on the right side down a few inches and is a single terminal.
Old 05-06-2006, 04:25 AM   #7
87supraguy
replaced oxygen sensor no difference but now i can small gas really bad drove around the block and couldnt stand the gas smell any more. Any clue as to what it could be fuel pressure regulator maybe? injectors?
any sugestions would be aprrecited
Old 05-06-2006, 11:09 AM   #8
f00g00
Default charcoal cannister?
Check all your connections to the charcoal cannister. Its supposed to burn the vapors that evaporate from the gas tank. If a hose came off then it could be the fumes from the tank venting in the atmosphere and entering the inside of the car. That is if there aren't any visible fuel leaks anywhere.
Old 05-06-2006, 08:45 PM   #9
87supraguy
canister hoses all conected. no fuel leaks anywhere went through that last year when i bought it and found out that the gas tank had a hole in it so i went through all the fuel lines and they all looked good. any other ideas?
Old 05-06-2006, 11:59 PM   #10
87supraguy
today i pulled all my plugs out to check them (did tune up last march) and now there is oil all over them. Could i have a bhg? could the oil on the plugs cause these problems? im starting to get frustrated with it please help if you can
Car started to over heat today. supraman121 MKIII Supra 5 10-02-2007 09:04 PM
It Started!!!!! ZauggIt1 MKIII Supra 0 11-09-2006 01:12 PM
stay away from h4 projector conversion on ebay turbo soup MKIII Supra 4 11-03-2006 09:06 AM
HELP! My engine just started a weird noise... idoke MKIII Supra 12 10-05-2006 05:06 PM
