Old 04-26-2006, 08:13 AM   #1
SCRAMJET
SCRAMJET's Avatar
Default Heater.
My heater isn't working. I can hear the heater mecanism trying to work but the valve must be stuck shut. Where is it located so i can free it up again?
Old 04-26-2006, 08:40 AM   #2
Kai
Kai's Avatar
Kai is on a distinguished road
From my own poking around the other day, most of the heater stuff is located behind the glovebox. Just remove the three screws underneath the glovebox and slide out the protective cover, and there is the heater blower motor, the resistor pack (which quite often dies - ?22 from Toyota), and the plenum/airducting.
HTH
Kai is offline   Reply With Quote
Old 04-26-2006, 08:47 AM   #3
SCRAMJET
SCRAMJET's Avatar
cheers mate. Was just lookin at the supra TSRM and it had i dodgy picture that sort of looked like behind the glove box but it didin't actually say. I'm off to rip my car to bits(yay). Thanks again..
Old 04-26-2006, 08:52 AM   #4
ddmcse
ddmcse's Avatar
actually the valve is located on the other side of the firewall
300+ RW HP Dyno run,
Blown HeadGasket info
My Supra KiXGaS
Old 04-26-2006, 08:58 AM   #5
SCRAMJET
SCRAMJET's Avatar
OK, I've found the servo unit that adjusts the heater. It seems to be working as normal. Any ideas on why i have no heat?
Old 04-26-2006, 11:31 AM   #6
Kai
Kai's Avatar
Checked that all the hoses run into the heater matrix and arent blocked? Thermostat not opening maybe? Are you getting the 'cappucino machine' sounds behind the dash?
Old 04-26-2006, 01:30 PM   #7
rnoswal
rnoswal's Avatar
Your control panel may have also bit the dust. They have been known to go bad from time to time. Is it blowing any air at all? Can you hear the fan when you put it on any of the three speeds? There may be a fuse for that stuff too.
Russ
Old 04-26-2006, 02:35 PM   #8
Kai
Kai's Avatar
If heat comes out of the vents, but only when driving along, then i suggest that it may be the resistor pack. Its mounted inside the ducting, secured by a single screw with a 6-pin plug going to it. Unplug it and take it out. If its dead, then Toyota still sells them, but if only one coil has gone - then you may be able to repair it. If that still doesnt work, i can only surmise that the control panel has indeed died, or has loose/faulty contacts - in which case, i'll be looking for one myself if the resistor pack i just ordered doesnt work!
Old 04-26-2006, 03:39 PM   #9
ddmcse
ddmcse's Avatar
there is a valve on the firewall i'll take pictures in a few minutes and post
it's a common problem
once you by-pass the valve you'll have heat
My Supra KiXGaS
Old 04-26-2006, 05:25 PM   #10
Reeves
Reeves is on a distinguished road
The "low" speed on mine doesn't seem to do anything, what can I do to fix it?
Reeves is offline   Reply With Quote
Heater hose locations suprabahamut MKIII Supra 4 12-16-2008 10:07 PM
location of heater core MKIIIBeast MKIII Supra 1 02-25-2008 02:00 PM
heater problem..... cold like heck... hangsupra MKIII Supra 9 01-28-2007 05:35 PM
Heater By-Passing...Your Thoughts mrnickleye Non-Generation Specific Questions 2 05-03-2006 03:06 PM
heater answers?? 1988gte MKIII Supra 14 12-05-2005 07:07 PM
