Old 04-18-2006, 10:15 PM   #11
extreme heat is the enemy
lean = heat
Old 04-19-2006, 09:50 AM   #12
lethalwithasupra
Nice site, ddmcse. And the car sounds awesome
Sooo ... afm + injectors from a Lexus ls400 v8 ? Any designation about the engine ... told it's " the 5.0L, " but others say they use a MAP sensor ...
Old 04-19-2006, 12:44 PM   #13
thanks !
sounds like DIESEL truck idling doesn't ?
Sooo ... afm + injectors from a Lexus ls400 v8 ? no .
i do not know about the lexus injectors working
it's the lexus air meter you want .
http://suprasonic.org/sonic/sonic.htm
go here scroll down
ALSO
for those that might also be wondering about the electronics of each AFM
quick search and came across this
Hello all! Its been a long time since I've written in, but I'm still
here
> > quietly enjoying the conversation in the background...
> > Anyhow, as the subject says, I would like to get a definitive answer on
the
> > Lexus AFM electronics.
> > My current (stock) AFM is on the fritz, and needs to be replaced. I want
to
> > do the Lexus upgrade someday, but not right now. -So, I'm thinking I
might
> > be able to get a whole Lexus AFM, then swap the electronics over to my
> > present AFM housing until such time as I want the larger Lexus AFM
> > housing....
> > I've read conflicting stories on various websites. Some people say the
Lexus
> > AFM electronics are identical. Others say you must swap out the Lexus
AFM
> > electronics with your Supra's stock electronics.
> > Which is correct? Is it possible that some Lexus AFMs have electronics
to
> > match our own, while others do not?
> I have used the electronics interchangeably without any apparent issue,
but I
> nore Reg Reimer's comments from here...
> http://www.supras.com/~riemer/lexusr...exusnotes.html which says "The
> Karman Vortex Electronic Sensor The electronics module on the Supra and
the
> Lexus air flow meters have numerically different part numbers but are
> dimensionally exactly the same size. Due to the part number difference on
the
> electronics module on the 7M-GTE and Lexus air flow meter, I only
recommend the
> use of the aluminum body of the Lexus air flow meter for this upgrade.
The
> electronic module from the stock 7M-GTE's air flow meter should be mounted
onto
> the Lexus air flow meters larger aluminum body with the three small
original
> Phillips mounting screws".
> Your choice I guess.
> Cheers
> Tony
Old 04-20-2006, 06:34 AM   #14
djalkyd
djalkyd's Avatar
djalkyd is on a distinguished road
Originally Posted by ddmcse
i didn't mean he has no respect for his car .
i mean that once you have to taken the sucker (engine) completely apart and gone through the agony and cost of rebuilding , you are left way more cautious and less tempted to beat the crap out of it .
i totally agree with you but what i am saying is that i lowered my boost to make up for the amount of air going in. stock boost is 8psi and i went down to 5psi. i ran on the dyno with a wide band under full load in all gears and the leanest it got was 14.9 to 1, when 14.7 to 1 is most desirable.
this week i am adding the injectors and the adjustable fpr with the s-afc so i can crank the boost up.
but i totally agree on the blood sweat and tears. i have been building my other car for years and have built many other peoples cars in the past so i know what you mean when you grenade or melt down internals.
i also thought you would have to use the stock sensor but i found out that the car responds better with the lexus sensor. for some reason unknown to me but it works.
djalkyd is offline   Reply With Quote
Lexus or Toyota AFM. What is the diference? azerty MKIII Supra 4 04-30-2008 01:08 PM
question on lexus maf swap supradrift MKIII Supra 1 07-18-2007 11:51 PM
