Old 04-03-2006, 10:36 PM   #1
G-string
G-string's Avatar
G-string is on a distinguished road
Default Metal in oil
big problem, i was backing outa my drive way yesterday and i didnt realive but my car liek dumped all its oil in like 70 meters so now its out of oil and i drive it around without realizing, there was no light or anything that came on. i got home and saw it so i ckeched the dip stick was dry and there were soem metal filings. Sooo what exactly does this mean :S
G-string is offline   Reply With Quote
Old 04-03-2006, 10:44 PM   #2
TONY!
TONY!'s Avatar
TONY! is on a distinguished road
Means you had metal to metal contact, and that you incurred some wear (as you know).
It may be from the bearings (your oil pressure may drop some).
It may be from the rings to cylinders sealing surfaces (you may have scratched up cylinder bores).
It may be from the oil pump (so it may work less effectively).
All you can do is just fill it up and test it out.
What else can you do at this point? Nothing but to just try it out and see how it goes.
If you are really curious, do a leak down test or compression test to see the how the sealing is for the cylinders. And keep an eye out to see if your oil pressure has dropped some.
If it works fine, just continue on.
If it starts to make weird sounds (as you should keep an ear out for), then you stop driving it immediately.
-------------> ITEMS THAT ARE STILL AVAILABLE FROM AN '88 PART OUT <-------------
_____|_____
_________________
/OO]====(W)====[OO\
[___________________]
[ [O] ///______\\\ [O]_]
____________________[||]______________[||]____________________
TONY! is offline   Reply With Quote
Non Metal Head Gasket 1988gte MKIII Supra 2 10-16-2007 04:31 AM
Hks Bead Metal Head Gasket Bore Size Help!!!!!!!! papaleach MKIII Supra 5 11-17-2006 11:27 PM
Metal to Metal dcrusupra MKIII Supra 7 09-30-2005 11:15 PM
