Old 04-01-2006, 12:47 AM   #1
Black'88
Black'88 is on a distinguished road
Default K&N FIPK
Thinking of getting a new intake system on my completely stock na supra. Is the fipk system a good place to start? Cause frankly its all I can afford atm...Or should I wait until I get afford intake as well as exhaust?
Also, Do I just order this:
http://suprastore.com/knfipairinsy.html
and put it on and thats all I should bother with intake? I've heard that the stock intake piping is quite restrictive so should I replace that too? If so where would I get new intake piping? Or should I not bother with that since I have a stock na engine (although I might go na-t somewhere in the future...distant future that is).
Thanks!
Black'88 is offline   Reply With Quote
Old 04-01-2006, 03:51 AM   #2
dcrusupra
dcrusupra's Avatar
Get an exhaust also. The Apex-i intake filter has better flow numbers than the K&N.
New Rebuild
My CarDomain
Old 04-01-2006, 04:02 AM   #3
Black'88
Got any pictures of an apex-i after installation? Does it just bolt onto the stock afm like the k8n fipk?
So apex-i is best intake system I can get? I wont see any improvements at all by just adding this intake system w/o adding an exhaust system as well? (btw, I do plan on getting exhaust in the future but theyre just so expensive and I want to modify my car after having it for 3 years :P)
Also, do these cai systems make the whooshing sound that I've heard about? If so, is it very noticeable from inside/outside the car?
Old 04-01-2006, 04:52 AM   #4
dcrusupra
dcrusupra's Avatar
I dont have pics after installation. Apex-i did have better flow numbers than the K&N filter. You would have a little gain without exhaust. None noticable though. And I had a cheepo one from Pep Boys that made the wooshing sound if i stomped on the gas. But I couldnt hear it from inside the car. I'd have to pull on the throttle cable in the engine bay to hear it. But in higher RPM mine started to hiss and sounds almost like a turbo. But the car next to u can hear it if they had their windows open and u went wide open throttle right away.
New Rebuild
My CarDomain
Old 04-01-2006, 08:19 PM   #5
Black'88
Nice, thats what I wanted to hear ;D
Whats a good exhaust system? Keep it legal now...
Old 04-01-2006, 09:20 PM   #6
kewlcoconut
the Apex-i filter does not fit NA supras. the bolt placement on the AFM is different for turbos and NA. I went through this problem. I ordered the Apexi from my tune up shop, and it didnt specify that it was for turbo at all. when i got it, took it home and it didnt fit. took it back, they called apex-i and then they said it was for turbo not NA. which they never said on their site at all. The bolts line up differently on the 2 AFMs. So i had to end up getting the K&N
Old 04-04-2006, 01:05 AM   #7
Burn N' Up
Burn N' Up's Avatar
I got a K&N FIPK, through out that oily ass AFM killing bullshit and got an AEM Dryflow 6"x5element" Higher flow rates than K&N with no oil, right out of the box, plus easy to wash. AEM you my only friend.
Edit: P.S. HKS Turbo exahust, good numbers and decent sound without the grapefruit launcher look. Just remember to paint it with high temp to ward off rust.
Old 04-04-2006, 02:58 AM   #8
Black'88
Got any links for that aem system? I cant find any that fits a supra. Thanks!
Old 04-04-2006, 09:28 PM   #9
lifesnotfair
Default Hrm...
935motorsports has a K&N FPIK for N/A supras. I'm thinking of buying one, says it's direct bolt on.
When upgrading a N/A Supra's exhaust, what exactly do you have to upgrade? I had a custom 2.5" exhaust made, with 2 resonators and a crappy muffler, but I didn't see anything that looked under 2.5" in diameter. Should this be helping already? I'm running stock air filter so maybe it's advisable to get the K&N FPIK?
'88 N/A automatic, looks, runs and feels like NEW!
Old 04-05-2006, 12:57 AM   #10
rnoswal
rnoswal's Avatar
I would just go to the parts store and buy a K&N stock replacement filter. It goes right in the original box, flows better and won't get wet.
As far as exhaust, the best way to go is with a good header and a larger, less restrictive exhaust system. The header will give you the best gains. Look for a good quatlity header, one with a good coating. The six cylinder sounds much better than a 4 cylinder engine, but if you can still get too annoying with the exhaust noise resonance inside the car with not a good enough type of muffler.
Russ
FIPK Question Spdfrk1990 MKIV Supra 1 05-15-2008 09:08 PM
K&N FIPK installation guid with pics azerty MKIII Supra 1 05-04-2008 02:12 PM
Do a K&N FIPK NON-TURBO fit a TURBO??? 88supra_dude Non-Generation Specific Questions 1 04-24-2008 06:17 AM
K&N Air Filter D_Train MKIII Supra 6 01-04-2008 07:27 PM
FIPK Kit for Non Turbo? bpalmer21 MKIV Supra 3 10-13-2006 01:44 AM
