Old 03-25-2006, 03:49 AM   #1
opeth_07
opeth_07 is on a distinguished road
Default HELP!!! My Hood is stuck closed!!
ok so i went to open my hood, pulled the latch, heard the click, but the hood didnt pop open as usual. Its done this once before, but it opened by playing with the hood a little. I already know that i need to replace the hood latch, but i still need to get into the hood before i can do that (i also need to put some oil in [stupid head gasket] so i can drive to work). Im thinking i can get to the latch from under the car, but if that doesnt work, then i could pry it somehow...but i dont want to damage the fender or any of the other components...if anyone knows another way...PLEASE let me know...
oh yeah shes an 87 7MGE
opeth_07 is offline   Reply With Quote
Old 03-25-2006, 03:28 PM   #2
Benesesso
Benesesso's Avatar
Benesesso is on a distinguished road
Use a strong plastic knife-you might try wrapping it in cloth. Then put a small coil spring on the latch mechanism to assist with popping it up against the safety catch for the future.
"You see, wire telegraph is like a very long cat. You pull his tail in New York and his head is meowing in Los Angeles. Do you understand this? Radio operates the same way: You send signals here, they receive them there. The only difference is there is no cat." A. Einstein
1988 and 1990 Turbo Supras
Benesesso is offline   Reply With Quote
Old 03-25-2006, 05:58 PM   #3
Jazzsaxsupra
Jazzsaxsupra is on a distinguished road
It's very possible that all you need to do is to lubricate the latch... keeping your latch lubed is important because it could cause you to bend the hood if you aren't careful. I've never had the problem of a stuck hood before... I've always maintained the latch... so I really wouldn't know how to get it open. Best of luck though!
Jazzsaxsupra is offline   Reply With Quote
Old 03-28-2006, 06:35 AM   #4
mrnickleye
mrnickleye's Avatar
Do a search on this forum, because this issue came up before, and it was a long thread. The answer is probably there.
Old 03-30-2006, 12:55 PM   #5
opeth_07
Thumbs up
already fixed...just needed some wd40...thanks guys!!
Hood release cable catawalks Non-Generation Specific Questions 11 04-24-2007 03:04 AM
HELP!!! My Hood is stuck closed!! opeth_07 Exterior , Interior, and Detailing 6 07-31-2006 06:02 PM
carbon fiber hood with hood scoop 86.5_supra MKIII Supra 0 05-10-2006 09:14 AM
HELP! Can't Open Hood - Cable Snapped. scruffboy Non-Generation Specific Questions 14 01-09-2006 12:29 AM
