Old 03-23-2006, 06:11 PM   #1
87nasupra
87nasupra is on a distinguished road
Exclamation need help please hurry!!!
ok i have a problem my engine has coolant leaking in to the oil im worried this is becasue of a bad gasket does anyone know why this is happening and what i have to do so i can fix it and stop the coolent from leaking into the engine ( oil)
87nasupra is offline   Reply With Quote
Old 03-23-2006, 06:16 PM   #2
j3pz
this is ussually a sign of a bhg. get a compression test done, all 6 cylinders should read around 160psi (sound correct?).
Old 03-23-2006, 06:19 PM   #3
87nasupra
Default comp test
ok how do i go about getting a comp test done? and if it is infact a bhg wel that sucks
Old 03-23-2006, 07:00 PM   #4
dcrusupra
dcrusupra's Avatar
If you have white smoke coming out of the exhaust, it smells like coolant, and the oil in the oil cap is kind of milky, then its a BHG.
New Rebuild
My CarDomain
Old 03-23-2006, 07:05 PM   #5
87nasupra
ok thats the thing i dont have a bellowing white smoke ( seen that befor) and my oil itsnt milky per say it looks thinner and has a slight very slight greaan tint to it and here the kicker sometimes i can smell coolent from my air vents thats what i dont like abot the hole thing so im not to sure whats going on
Old 03-24-2006, 06:04 PM   #6
j3pz
a local mechanic should be able to perform one. heard they might charge like $15 or something, or you could buy a compression gage and all the due-hickies and do it yourself.
Old 03-24-2006, 11:33 PM   #7
TONY!
TONY!'s Avatar
When you get coolant in the engine oil, you greatly decrease the oil's lubrication properties, then you get rod knock/spinning bearings (very expensive to fix).
Don't drive it or let that crap run through your engine oil passages if it is indeed oil and coolant mixing.
Is the oil foamy at all?
Do you have oil residue in your coolant overflow tank?
Performing a cooling system pressure test may or may not indicate a leak since sometimes leaks are intermittent. I would try it though anyways.
There are other tests, but they may be over your head (no offense--I was a new to engines to once).
Do you know of any mechanics that would let you borrow their tools?
_____|_____
_________________
/OO]====(W)====[OO\
[___________________]
[ [O] ///______\\\ [O]_]
Turbo Elbow on Ebay: Inexpensive Hurry! Bullz_EyE MKIII Supra 0 11-06-2005 09:50 AM
