Old 03-21-2006, 09:51 PM   #1
Kai
Kai's Avatar
Kai is on a distinguished road
Default Stupid Goddamn Radio
Dammit! I put one of those tape adapters into the radio so i could use my ipod on the move, and now, the adapter is stuck in there, the eject button does nothing, and although the tuner works and the radio goes 'beep' at me, theres no music from any of the radio stations or bands.
A) How do i remove the tape without permanently buggering up the radio
B) If i fail - how easy is it to remove the radio?
This is in an 88 UK Spec Supra - the Radio model is 5199
Kai is offline   Reply With Quote
Old 03-22-2006, 02:20 AM   #2
supra_91
supra_91's Avatar
the whole trim piece around the radio has to come out in order to get the radio out. maybe if you took your radio out you can take it apart and get the tape out?
Old 03-22-2006, 10:41 AM   #3
Kai
Kai's Avatar
Gah - the whole trim piece?!
*sigh* Anyone got a guide?
Old 03-22-2006, 02:30 PM   #4
supra_91
supra_91's Avatar
pull out the ashtray and there are 4 screws. there is 1 screw by the e-brake and another screw underneath you feet panel under the steering column
Old 03-22-2006, 06:39 PM   #5
Burn N' Up
Burn N' Up's Avatar
Its an easy removal to get the trim out, just rmember to DC the cigarette lighter, 4 way hazards and un screw the shifter cap. I've been there quite a bit, no biggy. don't lose the little black plastic pieces on the sides of the ash tray.
P.S. as blasphemous as it is, great title, i knew and understood your problem immediately.
Old 03-23-2006, 01:06 AM   #6
Kai
Kai's Avatar
Cheers for the reply - will attack it in the morning
Old 03-24-2006, 05:13 AM   #7
Burn N' Up
Burn N' Up's Avatar
Forgot to add, if yours is stick shift, to help remove the rear most portion of the trim, just through the leather of the shifter over hand style. You'll feel the frame, pull forward and up, it'll clear much easier then trying to yank straight up. hope it goes off well.
Old 06-20-2010, 02:06 PM   #8
usa203
usa203 is on a distinguished road
Default Great advice
I have been looking for this info or some time. Now I know where the remaing screws are located, not just the one I found on my own.
usa203 is offline   Reply With Quote
Old 06-20-2010, 02:08 PM   #9
oh and lower your stearing wheel all the way down.
it takes me about 20 seconds to take off and put on my trim molding.. i dont have any screws in .
Old 06-23-2010, 07:00 AM   #10
batmmannn
batmmannn's Avatar
Default Your Machine
Your tape was most likely eaten by the cassette player. This happens because the tape heads and rollers are sticky or dirty. While you are in there, clean the rollers and the tape head throughly with a Q-tip and rubbing alcohol. This should help. Oh wait that must be a transport problem because there is no tape with that adapter. Get one of those FM Ipod adapters that transmit your music to the FM radio there is no reason to be using that cassete deck at all unless you have cassettes that you want to listen to but I doubt that you would have any. Mine also has the stock radio, there are collectors looking for that radio, you could probably get enough for it on ebay to buy yourself a nice new aftermarket radio with CD player. Bezel Adapters for installing new radios are also on ebay. If its a transport problem I doubt you could find anyone that could fix it. Seems like the more you mess with those the worse they get
Stock Radio with CD Serge MKIII Supra 7 06-21-2010 12:45 PM
Radio lights? bills1988 MKIII Supra 5 08-23-2008 02:33 PM
Couple of Stupid Questions?? ZauggIt1 MKIII Supra 3 11-03-2006 07:14 AM
restarting radio after power loss. candace MKIII Supra 0 08-29-2006 03:13 AM
Help! Need Radio Expert scruffboy Non-Generation Specific Questions 3 11-13-2005 09:36 PM
