Old 03-19-2006, 08:02 AM   #1
wetwilly
wetwilly is on a distinguished road
Default help?!?
ok my battery died, so i replaced it... i put the new one in and the ALT fuse blew out, where can i get another one?? but now the car wont even start?? any answers why?? the car was running perfect, just accidently left headlights on.. help!!!??!?!! and its a brand new battery and the radio doesnt turn on, only the battery symbol on the dash..
wetwilly is offline   Reply With Quote
Old 03-19-2006, 10:19 AM   #2
djalkyd
djalkyd's Avatar
djalkyd is on a distinguished road
start with fuses then check if a ground is loose. check your main ground wire from the battery, if that one is good then check the grounds from the starter and block to frame.
djalkyd is offline   Reply With Quote
Old 03-20-2006, 01:06 PM   #3
big al
big al's Avatar
big al is on a distinguished road
are you certain its in the right way
better to check now then find out later
big al is offline   Reply With Quote
