Old 03-16-2006, 12:43 PM   #11
brs86supra
brs86supra is on a distinguished road
i tried to do a diagnostic and nothing happened it didnt even blink
brs86supra is offline   Reply With Quote
Old 03-16-2006, 12:45 PM   #12
brs86supra
changed my fuel filter and it looked like mud wasnt clean at all
Old 03-17-2006, 12:24 AM   #13
Normally (mostly) a dirty fuel filter will restrict the flow of fuel. So the signs of dirty one one is....the car will start and run OK up till a certain RPM, then it will start cutting out (misfiring). Dirtier ones will not allow the car to get up over a certain speed (like 50mph).
So the hard start when 'heat soaked' (as it is called) is not the filter.
Dirty injectors, carbon on the intake valves, a fuel system that won't hold the pressure after engine is off, a weak fuel pump (low pressure). These are the areas I'd be looking at if you came into the shop.
Old 03-17-2006, 03:37 AM   #14
kewlcoconut
im gonna look into the fuel pump. how much is this part? anyone know?
Old 03-17-2006, 05:07 AM   #15
The fuel pump is in the tank, and not a joy to replace. They aren't cheap either.
I suggest doing a fuel pressure test before replacing parts.
Old 03-17-2006, 09:07 PM   #16
Burn N' Up
Burn N' Up's Avatar
What does your exhaust smell like? Smell like raw gas? Any back firing? Cleaned your air filter lately?
Old 03-18-2006, 01:44 AM   #17
kewlcoconut
the exhaust doesnt smell like raw gas and to my knowledge, the car doesnt backfire. I know for a fact my filter is clean. the problem was present with the stock filter. Bought the K&N one, and it's still there. I will look into the fuel pressure test. I'm thinking thats the problem.
Thanks for all the help guys. Appreciate it. I will keep you posted on the testing.
Old 03-22-2006, 12:30 PM   #18
Synack
Synack is on a distinguished road
that happened with my 1993 318is
Synack is offline   Reply With Quote
Old 03-23-2006, 01:14 AM   #19
kewlcoconut
can you verify that it was the fuel pump?? or did you never get it fixed?
Old 03-23-2006, 09:47 AM   #20
kewlcoconut
i was browsing supramania forums and came across this thread.
http://www.supramania.com/forums/showthread.php?t=15243
wtf connections are these?(pics)
"I am just wondering what these two connections are and what exactly they do.
The first two pictures are a plug that was cracked during the headgasket change. It connects two pieces of vaccume line under the intake manifold."
Quote from JonoTurbo
"First two pics are the fuel pressure regulator vsv, you definitely want to fix that."
Quote from Red Dragon
"AFAIK, Fuel VSV is for hot starts to combatr heat soak, so if your car starts fine w/o it when hot then you are good to go. I don't have mine on there either"
The second quote struck me the most, I am going to check my car to see if that brown plug is connected to anything. If it isnt, where should it be connected to??
Car Died...where to start? Jrew MKIII Supra 4 10-26-2007 02:19 PM
