Old 03-04-2006, 12:57 PM   #1
Dejvid1785
Dejvid1785 is on a distinguished road
Default Torque Specifications (ARP Head Studs)???
I'm about to replace my head gasket and was wondering what is the best torque specification for my 88 na supra?, I'm using ARP head studs. Any help would be appreciated!
88 Targa: Exhaust, Headers, Intake
Dejvid1785 is offline   Reply With Quote
Old 03-04-2006, 12:59 PM   #2
Cool
i would say anywhere between 70 - 90 lbs
you pick the torque
stock torque is 55 lbs
Old 03-05-2006, 01:55 AM   #3
Strannik
Strannik is on a distinguished road
depends which lube you gonna use
Strannik is offline   Reply With Quote
Old 03-05-2006, 02:21 AM   #4
TONY!
TONY!'s Avatar
I thought when you buy their kit they give you their lube to go with it free, with instructions.
Or maybe you did not buy their kit yet?
If I remember correctly, it's like 85 foot lbs with their lube and higher if you use motor oil, but I would use the lube.
Old 03-05-2006, 03:43 AM   #5
kewlcoconut
they supply the lube with the kit you buy from them. i think mine was torqued to their specs.
Old 03-06-2006, 02:59 AM   #6
Dejvid1785
I ended up torquing it to 81lbs with their lube that ARP included. They say 75lbs with their lube or 120lbs with oil. We'll see how it turns out, thanx for the help!
ARP Head Studs frostburn MKIII Supra 4 08-22-2008 03:50 AM
Arp Head Stud Torque Settings!?!?!?!?!? papaleach MKIII Supra 2 11-22-2006 08:20 PM
torque settings for big end shells and cylinder head johnkarl MKIII Supra 4 11-03-2006 04:01 PM
Head Bolts, Or Head Studs?? ZauggIt1 MKIII Supra 2 08-08-2006 01:23 PM
Head bolt torque kjhsupra Non-Generation Specific Questions 3 04-06-2006 09:19 AM
