Old 03-04-2006, 06:02 AM   #1
BossHogg
BossHogg is on a distinguished road
Default Check engine codes
I just bought my supra and the check engine light is on and my speedometer doesn't work, I did a diagnostic check and got error codes 42,43, and 52. I think I can figure out code 53-the knock sensor, but I have no idea how to fix or wear the speed sensor signal is in order to get rid of this light and get my speedometer working agian. Does anyone have any advice?
BossHogg is offline   Reply With Quote
Old 03-04-2006, 08:46 AM   #2
joel w
joel w's Avatar
id pull the speedo cable loose at tranny and try to manually spin it while someone looks at the dash to see if it move.. speedo cable seems to be a common problem, there is a link somewhere about how to oil them, but if it was neglected too long, something can break or sieze..
Old 03-16-2006, 06:23 PM   #3
Isphius
Isphius's Avatar
waht side does the speedo cable bolt onto the trans? someone told me the adapter where it goes into the trans has something to do with it failing. where do i find this?
Old 03-17-2006, 12:14 AM   #4
mrnickleye
mrnickleye's Avatar
The cable on my '89 automatic goes into the rear of tranny on passenger side. It's hard to get to because of the mounts/frame etc.
I believe there is a split at the firewall 1/2 way down.
The speed sensor (check light problem) is in the speedo head. Hopefully its the cable bad. Otherwise I think you have to replace the speedometer to get the sensor.
Check Engine Light & Warning light on Chomper MKIV FAQ 19 02-11-2011 12:51 PM
Check Engine Light joebuffalo MKIII Supra 4 05-08-2007 03:01 PM
1987 supra turbo check engine lights kidthunder650 MKIII Supra 2 03-15-2007 01:34 AM
Check Engine Light Johnny boy 82 MKIII Supra 2 06-09-2006 09:41 PM
1998 Supra Check Engine Light SupraLady Non-Generation Specific Questions 2 12-15-2004 11:39 PM
