Old 02-05-2006, 12:22 AM   #1
MattJ
MattJ is on a distinguished road
Default battery warning light / tail lamp failure warning light
hello everyone!
I'm new to the ownership of the mystical Toyota Supra and a problem has reared its head already! lol
I have got an '87 supra with the 7M-GE engine.
Last night the battery light came on while driving and the 'volt' gauge now sits at about 10-11v. Also the 'rear light warning' light has come on the dash, are they related? I have had the rear lights checked out and all the lights work?
I assume the alternator might have decided to pack up but the problem just suddenly happened! One minute showing a healthy 14v on the gauge then down to 10v!
Is this a known problem at all? Like some dodgy earth or something?
Alternator looks easy to change but i dont want to unless i have to!
Thanks for any help
MattJ
MattJ is offline   Reply With Quote
Old 02-05-2006, 12:49 AM   #2
djalkyd
djalkyd's Avatar
djalkyd is on a distinguished road
thats a good question because my brake light lamp is on also. i was thinking it was fluid level or something but i added fluid but the light stays on. i just deal with it for now but it would be cool to have that thing off.
djalkyd is offline   Reply With Quote
Old 02-05-2006, 12:51 AM   #3
MattJ
Yeah it is a pain. only had the car 2 days!
Old 02-05-2006, 02:30 AM   #4
dcrusupra
dcrusupra's Avatar
Check the brake bulbs. If one is burned out the light usually goes on. I have no clue about the battery tho. Sorry.
New Rebuild
My CarDomain
Old 02-05-2006, 03:29 AM   #5
Burn N' Up
Burn N' Up's Avatar
Start trouble shooting. Get a multimeter and check the voltage in the battery. Then check the voltage and amperage coming off the alternator when the car is running. When running you should see 10A or less between the Alternator and Battery and 13.9-15.1v between the alternator and ground. If not get the battery tested at Autozone or Kragen or whatever and if the battery checks out, check all your fuses and start thinking about replacing the alternator or IC regulator. There is another test you can do to make sure its the alternator and not the IC regulator but you'd need a 30amp ammeter to do it. If everything checks out and its not the alternator or battery then its could be the gauge.
Hope this helps.
Old 02-06-2006, 07:22 PM   #6
MattJ
Thanks for the reply's
Turned out to be the alternator in the end
Matt
Check Engine Light & Warning light on Chomper MKIV FAQ 19 02-11-2011 12:51 PM
Brake light failure... RNEMESiS42 MKIII Supra 17 08-10-2008 12:53 AM
Warning light question scruffboy Non-Generation Specific Questions 4 06-11-2007 11:16 PM
warning lamp for rear lights on dashboard jarek MKIII Supra 7 10-12-2006 12:17 AM
Warning light question thetrueaint MKIII Supra 4 08-29-2006 06:07 AM
