Old 01-18-2006, 04:24 PM   #1
Supra4turbo20
Supra4turbo20 is on a distinguished road
Default upgrading my turbo
I have a 1988 supra turbo. Right now i am running a stock turbo, i was thanking about putting a T4 turbo on it or should i just upgrade to a bigger engine like a 1jz or a 2jz then put the T4 on one of those engines.
Supra4turbo20 is offline   Reply With Quote
Old 01-18-2006, 07:29 PM   #2
Bullz_EyE
Bullz_EyE's Avatar
Bullz_EyE is on a distinguished road
That all depends on how much money you have...
Function Over Form - Form Follows Function
88 MkIII Jurbo
Bullz_EyE is offline   Reply With Quote
Old 01-18-2006, 07:35 PM   #3
joel w
joel w's Avatar
im no turbo expert, but i think the t4 is the style of flange the turbo uses to connect to the manifold bolt pattern, so if you did, you will need a t4 tubular manifold to make it fit..? any one step in if this is wrong..
i have no experience with a 1jz or 2jz so i cant answer that..
Old 01-19-2006, 04:41 PM   #4
Supra4turbo20
My Friend has a 1989 supra turbo, he is running e-MANAGE ULTIMATE. This guy knows a lot about older supras and he is the guy that is going to give me the T4 turbo with a manifold and a wast gate, he used it on his car, but i have a some miles on my car i am thanking blowing my engine up
Old 01-19-2006, 05:31 PM   #5
Bullz_EyE
Bullz_EyE's Avatar
Is your vehicle stock? How would you rate the condition of your engine? I'd give it a 2nd thought before bolting on that turbo setup. You'll definitely need some sort of tuning. At least upgrade the fuel system and AFM before you think about hooking up that turbo. You'll also need a custom downpipe and you'll need to upgrade your exhaust if you use it.
88 MkIII Jurbo
Old 01-20-2006, 03:32 AM   #6
kwnate
SP58GT
7m 3.0 liter 232hp single turbo
1jz 2.5 liter 275hp? twin turbo
2jz 3.0 liter 320hp twin turbo
You can make tons of hp with any of em if you do it right...
Nate
Old 01-20-2006, 04:42 PM   #7
Supra4turbo20
Right now all i have on my car is just a bigger airflow meter an intake, an HKS exhaust, turbo timer, i just got my Greddy e-01 boost controller. I got my supra for $1000 it was a good deal. It came with the HKS exhaust,HKS turbo timer and an HKS boost controller, but i dont like the hks boost controller sucks i could not find out how to tune my boost so i just got the greddy one it is a lot better. There is a lot i am going to do to it i have just started.
upgrading 1987 turbo Prez420 MKIII Supra 22 09-24-2005 03:03 PM
