Old 01-18-2006, 02:17 PM   #11
lifesnotfair
Default e-Bay.
Though I haven't got it yet, as it needs to fly overseas to get to me.
Buy a used one, they're usually about 10 USD$.
'88 N/A automatic, looks, runs and feels like NEW!
Old 01-18-2006, 06:07 PM   #12
j3pz
check ebay pal. people selling those or parting out cars will sell them for cheap. like $10 usd
Old 01-18-2006, 06:19 PM   #13
lifesnotfair
Default Heh!
Lol bro, your reply was nearly identical to mine.. probably you didn't see it as mine was on 2nd page.
Old 01-18-2006, 07:06 PM   #14
j3pz
i saw it, i just wanted to make sure he knows they are cheaper used and can get em over ebay. not trying to take your credit
Old 05-03-2006, 02:37 AM   #15
ice2x01
ice2x01 is on a distinguished road
Originally Posted by j3pz
ya i read something like that somewhere. the box or sensor or whatever sometimes screws up and wont let the lights work. you can bypass this but then the light on the dash stays lit. think i read it on sogi
sorry to bring a thread back from the dead, but I just got a supra and am having the same exact problem, does anyone have details on this bypass?
Thanks
ice2x01 is offline   Reply With Quote
Old 05-02-2008, 07:56 PM   #16
Subjug4tor
Subjug4tor is on a distinguished road
now im really raising the dead with this thread, but im also curious about the bypass mentioned here...
Subjug4tor is offline   Reply With Quote
Old 05-03-2008, 03:36 AM   #17
spudz29212MKIII
spudz29212MKIII's Avatar
Well, I had same problem with the taillights (rear hatch leak). I had water get into Tailight Failure Sensor and also corroded my taililights. I also took off my wing and plugged the wholes but, I replaced the third light with the bulb and threw some tape on it so the warning light would shut up. Anywho
I bought a used Tail Failure Sensor on ebay (**be sure you match the part numbers from your original one**) threw that on, yet still tail lights where not operating correctly. (i also checked all my relays and switches, which is a good idea).
What I finally did that fixed it was: I ripped all the tail lights out, got new pigtails, new bulbs, and some di-electric grease. I completely dissasembled it all cleaned and re-wired with new everything, minus the bulb holders (idk the proper name for them) i just cleaned them.
Threw some di-electric grease on the bulbs and new pigtails, installed and I was good to go everything works fine..If your new to wiring you might need some help..but thier is some helpful directions from supramania : How-To:Repair tail lights - SupraMania
Dont know what path you will take but this is what worked for me
Zach
Old 05-05-2008, 12:25 PM   #18
zebrahabitz
zebrahabitz is on a distinguished road
i have an 87' supra.....and i had the same problem, first i checked the bulbs, bulbs were good, then i checked the fuse, the fuse was good, then i checked the "yellow box" you were talking about, i opened it up and found a burnt circuit( the box is under the driver's tailight ), so i replaced it and the brakes work perfect now........i got it on ebay LAMP FAILURE TOYOTA model no. 89373-32120, its cheap and easy to fix, because the toyota dealer was charging me 280 over here in jersey..........hope it helped you
zebrahabitz is offline   Reply With Quote
Old 05-05-2008, 11:40 PM   #19
Subjug4tor
well i checked my yellow box (lamp failure sensor), and it looked okay, but my lamp terminals were super corroded, and i had a semi-loose ground wire. cleaned everything and fixed the ground and it works fine now.
Brake Lights zebrahabitz MKIII Supra 2 08-13-2009 06:29 AM
Dash lights and Side marker lights are not working ebang MKIII Supra 0 04-01-2008 12:35 PM
87 supra brake lights ministrytrav MKIII Supra 4 11-23-2005 08:53 PM
brake lights problem MWoz34 MKIII Supra 2 09-14-2005 03:08 AM
