Old 12-19-2005, 08:32 AM   #1
kewlcoconut
kewlcoconut is on a distinguished road
Default Removing resonator?
Good idea to remove the resonator? I'm still looking into changing my whole exhaust system. From headers down to my exhaust. But I wanted to know if the resonator is really necessary.
kewlcoconut is offline   Reply With Quote
Old 12-19-2005, 02:57 PM   #2
SupraMan1784
SP58GT
if i remember correctly removing the resonator wont really do much, it might free up the flow a little bit, but it will probably make a little more noise... with anal cops making sure ur below the dB level over here it makes a difference and you'll probably want to avoid the confrontation
Now: Saving for an MKIV
Broken Rides:
Old 12-20-2005, 02:24 AM   #3
mrnickleye
mrnickleye's Avatar
From my thread in the FAQs section....
I went with a Magnaflow straight thru muffler (packing inside). It was too loud for me because it is at the end of the pipe, and it created an awful drony deep tone at cruising of 2k RPMs. So...I ADDED a 24" straight thru glass packed, 4" diameter muffler in the middle of the system (middle of car). Now it has a great sound, with an unresticted flow, and just enough back pressure to keep my torque high at lower RPMs.
I have a slightly modded '89 N/A. The 6 cyl sounds very throaty, with out drawing the cops down on me.
Old 12-21-2005, 06:20 AM   #4
1988gte
1988gte is on a distinguished road
what is and where is this resonator
1988gte is offline   Reply With Quote
Old 12-21-2005, 06:37 AM   #5
mrnickleye
mrnickleye's Avatar
The resonator is a small muffler in the exhaust, after the cat convertor. It is located under the center console. Many have been removed thru the years. With a decent muffler at the back, you can remove it without being "too" loud.
It really helps cut down on the "drone" sound that is created at certain RPMs. Without it, at 2k, it sucked. It gave me a headache to drive for 30 min.
Old 12-21-2005, 06:43 AM   #6
1988gte
maybe not a good idea i drive 25 miles to and from work everyday at highway speeds
Removing carbon canister, fuel evap. emissions pdogg Non-Generation Specific Questions 2 09-17-2008 06:58 AM
Having Trouble Removing the Steering Wheel Chambers MKIII Supra 3 06-30-2008 01:03 AM
removing a 7mgte from MK3 tokis MKIII Supra 2 11-17-2007 03:34 AM
Removing the struts supraman121 MKIII Supra 7 10-15-2007 02:53 AM
Removing the SAFC-2 MDellboy420 MKIII Supra 0 01-27-2006 03:02 PM
